Hi to all!
Is there a nice way to add the microphone volume bar in the taskbar in the same way there is the speaker bar?
Thanks in advance,
OcirneMat
Hi to all!
Thanks in advance,
OcirneMat
Hi to all,
Just for the others, I managed to find a solution, but adding this gnome extension
First you need to install the gnome-tweaks
sudo apt install gnome-tweaks
Then you need to follow the instructions here
Take always the last versions from the website, but here what I did:
mkdir ~/.local/share/gnome-shell/extensions/
cd ~/.local/share/gnome-shell/extensions/
# Remove older version
rm -rf *sound-output-device-chooser*
# Clone current version
sudo apt install git
git clone https://github.com/kgshank/gse-sound-output-device-chooser.git
# Install it
cp -r gse-sound-output-device-chooser/sound-output-device-chooser@kgshank.net .
rm -rf "gse-sound-output-device-chooser"
You have a nice microphone bar below the audio sound bar. Amazing!
Hope it helps,
OcirneMat
