Hi, during install of Zorin 17, during boot and after boot in logs I noticed these :
update-initramfs: Generating /boot/initrd.img-6.6.8-060608-generic
W: Possible missing firmware /lib/firmware/amdgpu/ip_discovery.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega10_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_14_0_0_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_14_0_0_toc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_6_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_6_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_9_4_3_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_9_4_3_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_toc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_4_4_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_1_0.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vcn_4_0_3.bin for module amdgpu
What to do and do I need to worry ?
Btw, I tried to install latest kernel , and still it is the same as on default kernel
Please note that the Firmware discussed above and the BIOS FIrmware are two different things.
That said, some of the errors in the above post suggest that a BIOS firmware may be advisable. If you can check if there are any available for your make and model.
