Hello Everyone,
I recently switched to Zorin OS & loving it. I have been using WiFi, but have hardwired accessible, but prefer not to use it. On to the problem. WiFi went missing. Poof. Gone. The Strange part about this is, WiFi was detected upon install, I was able to use WiFi for several days. The only thing I can think of is my snap installing binge, but that seems like it shouldn't be a problem.
Any advice on how to find it again? What information do you need?
joshuamwolfe@desktop:/etc/apt$ snap list
Name Version Rev Tracking Publisher Notes
antstream-arcade 2.1.2469 15 latest/stable antstream -
atom 1.57.0 282 latest/stable snapcrafters classic
bare 1.0 5 latest/stable canonicalâś“ base
beekeeper-studio 2.1.4 113 latest/stable matthew-rathbone -
code 7f6ab548 75 latest/stable vscodeâś“ classic
core 16-2.51.7 11743 latest/stable canonicalâś“ core
core18 20210722 2128 latest/stable canonicalâś“ base
core20 20210702 1081 latest/stable canonicalâś“ base
gitkraken 8.0.1 183 latest/stable gitkrakenâś“ classic
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 161 latest/stable canonicalâś“ -
gpassmanager 1.1.0 68 latest/stable injamulmd -
gtk-common-themes 0.1-59-g7bca6ae 1519 latest/stable canonicalâś“ -
postman 8.12.2 147 v8/stable postman-incâś“ -
powershell 7.1.4 182 latest/stable microsoft-powershellâś“ classic
pycharm-community 2021.2.2 252 latest/stable jetbrainsâś“ classic
skype 8.75.0.140 183 latest/stable skypeâś“ -
snapd 2.51.7 13170 latest/stable canonicalâś“ snapd
utilso 4.0.0 27 latest/stable sleptsov -
webstorm 2021.2.2 221 latest/stable jetbrainsâś“ classic
Integrated WiFi on motherboard, Info below:
dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.2.0 present.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: TUF GAMING X570-PLUS (WI-FI)
Version: Rev X.0x
Serial Number: 200670255100716
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Let me take a quick guess. You've had WIFI turned off during the entire OS session, that computer was on, then decided to use it, and turned the WIFI toggle back on correct?
Restart the computer, that will probably solve it. If not, we can dive further into this.
Storm
September 30, 2021, 5:21am
3
I had a wifi card that went missing. What helped was to turn off the computer/the power and detached the wifi card in 10 minutes time and then put it back in.
sudo lshw results part one
desktop
description: Desktop Computer
product: System Product Name (SKU)
vendor: System manufacturer
version: System Version
serial: System Serial Number
width: 64 bits
capabilities: smbios-3.2.0 dmi-3.2.0 smp vsyscall32
configuration: boot=normal chassis=desktop family=To be filled by O.E.M. sku=SKU uuid=8EFEC6C9-3367-7F0C-B80A-244BFE594223
*-core
description: Motherboard
product: TUF GAMING X570-PLUS (WI-FI)
vendor: ASUSTeK COMPUTER INC.
physical id: 0
version: Rev X.0x
serial: 200670255100716
slot: Default string
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 1407
date: 04/01/2020
capacity: 16MiB
capabilities: pci apm upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: 32
slot: System board or motherboard
*-bank:0
description: DIMM DDR4 Synchronous Unbuffered (Unregistered) 2133 MHz (0.5 ns)
product: CMK16GX4M2B3200C16
vendor: Corsair
physical id: 0
serial: 00000000
slot: DIMM_A1
width: 64 bits
clock: 2133MHz (0.5ns)
*-bank:1
description: [empty]
product: Unknown
vendor: Unknown
physical id: 1
serial: Unknown
slot: DIMM_A2
*-bank:2
vendor: Corsair
physical id: 2
serial: 00000000
slot: DIMM_B1
width: 64 bits
*-bank:3
product: Unknown
vendor: Unknown
physical id: 3
serial: Unknown
slot: DIMM_B2
*-cache:0
description: L1 cache
physical id: 35
slot: L1 - Cache
capacity: 384KiB
clock: 1GHz (1.0ns)
capabilities: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 36
slot: L2 - Cache
capacity: 3MiB
clock: 1GHz (1.0ns)
configuration: level=2
*-cache:2
description: L3 cache
physical id: 37
slot: L3 - Cache
capacity: 32MiB
clock: 1GHz (1.0ns)
configuration: level=3
*-cpu
description: CPU
product: AMD Ryzen 5 3600X 6-Core Processor
vendor: Advanced Micro Devices [AMD]
physical id: 38
bus info: cpu@0
version: AMD Ryzen 5 3600X 6-Core Processor
serial: Unknown
slot: AM4
capacity: 4408MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate sme ssbd mba sev ibpb stibp vmmcall sev_es fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif umip rdpid overflow_recov succor smca cpufreq
configuration: cores=6 enabledcores=6 threads=12
*-pci:0
description: Host bridge
product: Starship/Matisse Root Complex
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 33MHz
*-generic UNCLAIMED
description: IOMMU
product: Starship/Matisse IOMMU
physical id: 0.2
bus info: pci@0000:00:00.2
version: 00
width: 32 bits
clock: 33MHz
capabilities: msi ht cap_list
configuration: latency=0
*-pci:0
description: PCI bridge
product: Starship/Matisse GPP Bridge
physical id: 1.2
bus info: pci@0000:00:01.2
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:27 ioport:f000(size=4096) memory:f7200000-f77fffff
*-pci
product: Matisse Switch Upstream
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi normal_decode bus_master cap_list
resources: irq:24 ioport:f000(size=4096) memory:f7200000-f77fffff
*-pci:0
product: Matisse PCIe GPP Bridge
physical id: 4
bus info: pci@0000:02:04.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:34 memory:f7700000-f77fffff
*-network
description: Network controller
product: Wireless-AC 9260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 29
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:24 memory:f7700000-f7703fff
*-pci:1
physical id: 5
bus info: pci@0000:02:05.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:35 ioport:f000(size=4096) memory:f7600000-f76fffff
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 26
serial: 24:4b:fe:59:42:23
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.11.0-37-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.201 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:37 ioport:f000(size=256) memory:f7604000-f7604fff memory:f7600000-f7603fff
*-pci:2
physical id: 8
bus info: pci@0000:02:08.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:36 memory:f7200000-f73fffff
*-generic UNCLAIMED
description: Non-Essential Instrumentation
product: Starship/Matisse Reserved SPP
physical id: 0
bus info: pci@0000:05:00.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress cap_list
*-usb:0
description: USB controller
product: Matisse USB 3.0 Host Controller
physical id: 0.1
bus info: pci@0000:05:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:41 memory:f7300000-f73fffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.11.0-37-generic xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 5.11
capabilities: usb-2.00
configuration: driver=hub slots=6 speed=480Mbit/s
*-usb
description: Audio device
product: G733 Gaming Headset
vendor: Logitech
physical id: 4
bus info: usb@1:4
version: 1.00
capabilities: usb-1.10 audio-control
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.11
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-usb:1
physical id: 0.3
bus info: pci@0000:05:00.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix xhci bus_master cap_list
resources: irq:39 memory:f7200000-f72fffff
*-usbhost:0
physical id: 0
bus info: usb@3
logical name: usb3
version: 5.11
*-usb:0
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: 5
bus info: usb@3:5
version: 0.02
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usb:1
description: Human interface device
product: AURA LED Controller
vendor: AsusTek Computer Inc.
physical id: 6
bus info: usb@3:6
version: 1.00
serial: 9876543210
configuration: driver=usbhid maxpower=16mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@4
logical name: usb4
version: 5.11
*-pci:3
physical id: 9
bus info: pci@0000:02:09.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:38 memory:f7500000-f75fffff
*-sata
description: SATA controller
product: FCH SATA Controller [AHCI mode]
physical id: 0
bus info: pci@0000:06:00.0
version: 51
width: 32 bits
clock: 33MHz
capabilities: sata pm pciexpress msi ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:42 memory:f7500000-f75007ff
*-pci:4
physical id: a
bus info: pci@0000:02:0a.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:40 memory:f7400000-f74fffff
*-sata
physical id: 0
bus info: pci@0000:07:00.0
version: 51
width: 32 bits
clock: 33MHz
resources: irq:60 memory:f7400000-f74007ff
*-pci:1
physical id: 3.1
bus info: pci@0000:00:03.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:28 ioport:e000(size=4096) memory:f6000000-f70fffff ioport:e0000000(size=303038464)
*-display
product: TU116 [GeForce GTX 1660 SUPER]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:08:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:113 memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
*-multimedia
product: TU116 High Definition Audio Controller
physical id: 0.1
bus info: pci@0000:08:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:109 memory:f7080000-f7083fff
*-usb
product: TU116 USB 3.1 Host Controller
physical id: 0.2
bus info: pci@0000:08:00.2
version: a1
width: 64 bits
clock: 33MHz
capabilities: msi pciexpress pm xhci cap_list
resources: irq:89 memory:f2000000-f203ffff memory:f2040000-f204ffff
*-usbhost:0
physical id: 0
bus info: usb@5
logical name: usb5
version: 5.11
configuration: driver=hub slots=2 speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@6
logical name: usb6
version: 5.11
*-serial
description: Serial bus controller
product: TU116 [GeForce GTX 1650 SUPER]
physical id: 0.3
bus info: pci@0000:08:00.3
version: a1
width: 32 bits
clock: 33MHz
capabilities: msi pciexpress pm bus_master cap_list
configuration: driver=nvidia-gpu latency=0
resources: irq:59 memory:f7084000-f7084fff
*-pci:2
product: Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
physical id: 7.1
bus info: pci@0000:00:07.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:30
*-generic UNCLAIMED
product: Starship/Matisse PCIe Dummy Function
physical id: 0
bus info: pci@0000:09:00.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 8.1
bus info: pci@0000:00:08.1
version: 00
width: 32 bits
clock: 33MHz
resources: irq:31 memory:f7800000-f7afffff
*-generic:0 UNCLAIMED
physical id: 0
bus info: pci@0000:0a:00.0
version: 00
width: 32 bits
clock: 33MHz
*-generic:1
description: Encryption controller
product: Starship/Matisse Cryptographic Coprocessor PSPCPP
physical id: 0.1
bus info: pci@0000:0a:00.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list
configuration: driver=ccp latency=0
resources: irq:100 memory:f7900000-f79fffff memory:f7a08000-f7a09fff
*-usb
physical id: 0.3
bus info: pci@0000:0a:00.3
version: 00
width: 64 bits
clock: 33MHz
resources: irq:90 memory:f7800000-f78fffff
*-usbhost:0
physical id: 0
bus info: usb@7
logical name: usb7
version: 5.11
configuration: driver=hub slots=4 speed=480Mbit/s
*-usb:0
description: Mouse
product: Gaming Mouse G600
vendor: Logitech
physical id: 1
bus info: usb@7:1
version: 77.02
serial: BBF5FCB139B20017
configuration: driver=usbhid maxpower=500mA speed=12Mbit/s
*-usb:1
description: Keyboard
product: Razer Ornata Chroma
vendor: Razer
physical id: 3
bus info: usb@7:3
version: 2.00
*-usb:2
description: Video
product: Webcam C270
vendor: Logitech, Inc.
physical id: 4
bus info: usb@7:4
version: 0.12
serial: 7754B6D0
configuration: driver=snd-usb-audio maxpower=500mA speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@8
logical name: usb8
version: 5.11
*-multimedia
product: Starship/Matisse HD Audio Controller
physical id: 0.4
bus info: pci@0000:0a:00.4
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
resources: irq:111 memory:f7a00000-f7a07fff
*-pci:4
physical id: 8.2
bus info: pci@0000:00:08.2
version: 00
width: 32 bits
clock: 33MHz
resources: irq:32 memory:f7c00000-f7cfffff
*-sata
physical id: 0
bus info: pci@0000:0b:00.0
version: 51
width: 32 bits
clock: 33MHz
resources: irq:85 memory:f7c00000-f7c007ff
*-pci:5
physical id: 8.3
bus info: pci@0000:00:08.3
version: 00
width: 32 bits
clock: 33MHz
resources: irq:33 memory:f7b00000-f7bfffff
*-sata
physical id: 0
bus info: pci@0000:0c:00.0
version: 51
width: 32 bits
clock: 33MHz
resources: irq:87 memory:f7b00000-f7b007ff
*-serial
description: SMBus
product: FCH SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 61
width: 32 bits
clock: 66MHz
configuration: driver=piix4_smbus latency=0
resources: irq:0
*-isa
description: ISA bridge
product: FCH LPC Bridge
physical id: 14.3
bus info: pci@0000:00:14.3
version: 51
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
*-pci:1
product: Starship/Matisse PCIe Dummy Host Bridge
physical id: 101
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
physical id: 102
bus info: pci@0000:00:02.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 103
bus info: pci@0000:00:03.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 104
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:5
physical id: 105
bus info: pci@0000:00:05.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
physical id: 106
bus info: pci@0000:00:07.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:7
physical id: 107
bus info: pci@0000:00:08.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:8
product: Matisse Device 24: Function 0
physical id: 108
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:9
product: Matisse Device 24: Function 1
physical id: 109
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
part two + neofetch
*-pci:10
product: Matisse Device 24: Function 2
physical id: 10a
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:11
product: Matisse Device 24: Function 3
physical id: 10b
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k10temp
resources: irq:0
*-pci:12
product: Matisse Device 24: Function 4
physical id: 10c
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:13
product: Matisse Device 24: Function 5
physical id: 10d
bus info: pci@0000:00:18.5
version: 00
width: 32 bits
clock: 33MHz
*-pci:14
product: Matisse Device 24: Function 6
physical id: 10e
bus info: pci@0000:00:18.6
version: 00
width: 32 bits
clock: 33MHz
*-pci:15
product: Matisse Device 24: Function 7
physical id: 10f
bus info: pci@0000:00:18.7
version: 00
width: 32 bits
clock: 33MHz
*-pnp00:00
product: PnP device PNP0c01
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0c02
physical id: 2
capabilities: pnp
*-pnp00:02
product: PnP device PNP0b00
physical id: 3
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:03
physical id: 4
capabilities: pnp
*-pnp00:04
product: PnP device PNP0501
physical id: 5
capabilities: pnp
configuration: driver=serial
*-pnp00:05
physical id: 6
capabilities: pnp
*-scsi:0
physical id: 7
logical name: scsi2
capabilities: emulated
*-disk
description: ATA Disk
product: ST1000LX015-1U71
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sda
version: SDM1
serial: ZKP041MQ
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=25ffd8f7-12ab-4f8a-a340-55a149e868cd logicalsectorsize=512 sectorsize=4096
*-volume:0 UNCLAIMED
description: Windows FAT volume
vendor: mkfs.fat
physical id: 1
bus info: scsi@2:0.0.0,1
version: FAT32
serial: 39dd-ff17
capacity: 511MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat name=EFI System Partition
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@2:0.0.0,2
logical name: /dev/sda2
logical name: /
version: 1.0
serial: 3b4b87f6-1698-4d3b-a46f-e64d684964f1
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2021-09-27 09:18:27 filesystem=ext4 lastmountpoint=/ modified=2021-09-29 23:53:37 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro mounted=2021-09-29 23:53:38 state=mounted
*-scsi:1
physical id: 8
logical name: scsi3
*-disk
product: WDC WDS500G2B0A
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@3:0.0.0
logical name: /dev/sdb
version: 00WD
serial: 2032A6800660
configuration: ansiversion=5 guid=f1ca7f2e-cc6d-4735-8b88-4b7d0edd632b logicalsectorsize=512 sectorsize=512
*-volume:0
description: reserved partition
vendor: Windows
physical id: 1
bus info: scsi@3:0.0.0,1
logical name: /dev/sdb1
serial: fbd2137f-022a-44ce-b2bd-af3f21ddb492
capacity: 15MiB
capabilities: nofs
configuration: name=Microsoft reserved partition
*-volume:1
description: Windows NTFS volume
vendor: Windows
physical id: 2
bus info: scsi@3:0.0.0,2
logical name: /dev/sdb2
version: 3.1
serial: e6bbd612-f5c5-704b-ad9a-aaa2e5bef968
capacity: 465GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2020-11-29 18:00:23 filesystem=ntfs label=Data name=Basic data partition state=clean
*-scsi:2
physical id: 9
logical name: scsi8
*-disk
product: Samsung SSD 860
physical id: 0.0.0
bus info: scsi@8:0.0.0
logical name: /dev/sdc
version: 4B6Q
serial: S59VNS0N804963K
configuration: ansiversion=5 guid=1c15a484-4061-4b83-9c2d-83563ff9796e logicalsectorsize=512 sectorsize=512
*-volume:0
vendor: MSDOS5.0
physical id: 1
bus info: scsi@8:0.0.0,1
logical name: /dev/sdc1
version: FAT32
serial: 4864-fb53
capacity: 99MiB
capabilities: boot nomount fat initialized
configuration: FATs=2 filesystem=fat name=EFI system partition
*-volume:1
vendor: Windows
physical id: 2
bus info: scsi@8:0.0.0,2
logical name: /dev/sdc2
serial: f4800bb3-c612-4444-861a-8e5c5efed074
capacity: 15MiB
capabilities: nofs nomount
*-volume:2
vendor: Windows
physical id: 3
bus info: scsi@8:0.0.0,3
logical name: /dev/sdc3
version: 3.1
serial: dafbf8f0-8c42-2c4a-8d35-0244f6900e18
capacity: 930GiB
configuration: clustersize=4096 created=2020-11-30 01:16:59 filesystem=ntfs name=Basic data partition state=clean
*-volume:3
vendor: Windows
physical id: 4
bus info: scsi@8:0.0.0,4
logical name: /dev/sdc4
version: 3.1
serial: 0c68-b6b4
capacity: 587MiB
capabilities: boot precious nomount ntfs initialized
configuration: clustersize=4096 created=2021-09-24 13:41:30 filesystem=ntfs state=clean
neofetch
`osssssssssssssssssssso` joshuamwolfe@desktop
.osssssssssssssssssssssso. --------------------
.+oooooooooooooooooooooooo+. OS: Zorin OS 16 x86_64
Kernel: 5.11.0-37-generic
Uptime: 1 hour, 25 mins
`::::::::::::::::::::::. .:` Packages: 2502 (dpkg), 64 (flatpak), 20 (snap)
`+ssssssssssssssssss+:.` `.:+ssso` Shell: bash 5.0.17
.ossssssssssssssso/. `-+ossssssso. Resolution: 1920x1080, 1920x1080
ssssssssssssso/-` `-/osssssssssssss DE: GNOME
.ossssssso/-` .-/ossssssssssssssso. WM: Mutter
`+sss+:. `.:+ssssssssssssssssss+` WM Theme: ZorinGreen-Dark
`:. .::::::::::::::::::::::` Theme: ZorinGreen-Dark [GTK2/3]
Icons: ZorinGreen-Dark [GTK2/3]
Terminal: gnome-terminal
.+oooooooooooooooooooooooo+. CPU: AMD Ryzen 5 3600X (12) @ 3.800GHz
-osssssssssssssssssssssso- GPU: NVIDIA GeForce GTX 1660 SUPER
`osssssssssssssssssssso` Memory: 2606MiB / 15915MiB
I have been looking into the issue, I want you to do a couple things...
(1) Go into the BIOS, make sure SECURE BOOT
and FAST BOOT
are disabled please.
If issue is still present...
(2)
apt-get --reinstall install linux-firmware
Still missing. I had to delete the keys to get secure boot to go off. I'll try #2 a second time and see what happens.
I finally have been able to log in to my desktop after a couple of days. WiFi inexplicably is working now. I'll update you guys in a week or so. Here is the data you requested, just in case.
joshuamwolfe@desktop:~$ sudo lshw -c network
[sudo] password for joshuamwolfe:
*-network
physical id: 0
logical name: wlp3s0
version: 29
serial: bc:54:2f:d1:f4:6b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.11.0-37-generic firmware=46.4d093a30.0 9260-th-b0-jf-b0- ip=192.168.86.25 latency=0 link=yes multicast=yes wireless=IEEE 802.11
*-network
physical id: 0
version: 26
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
The only thing that changed is I started windows. I dont go to windows often, but; when, I came back, it was gone again. It's on a completely separate hard drive, didn't think that would matter. Any idea's on what I should look for next?
I have a funny feeling we have seen this behaviour here before now. I will try and find the thread.
EDIT:
Whilst this link is not to the thread on here that I was thinking of, it may be of interest as it is same wifi adapter and there is a marked solution.
EDIT2: Last time you said wifi came back on its own accord after PC had been off for some time. Have you completely powered it down again since running Zorin (instead of after Windows) and see if it magically reappears again.
EDIT3: Also see this: Linux* Support for Intel® Wireless Adapters
I think I know where Zaba is getting at with his post. Whenever you completely shut a computer off, and then power it back on again, stuff that was stored in RAM is cleared. Where as if you do a simply restart, the RAM isn't necessarily cleared.
I want to dive into this, but I need to wait a few days, very busy. I appreciate the help.
Hey guys, it's been a while with no change. WIFI not going on vacation anymore. Something you guys told me to do fixed the issue. Thanks for the help!
We are so good... We don't even know what we did or who did it.
Good to hear that. If you can pinpoint which post helped you fix the problem, then can you mark it as Solution.
That will be useful for others that may read this in the future.
I'll do some poking around and keep you updated.
system
Closed
April 23, 2022, 9:26pm
19
