Modprobe: FATAL: Module efivars not found in directory /lib/modules/6.17.0-20-generic
I have inserted the boot info at the bottom. I have a Lenovo and set up windows 11 in one partiton and Zorin 18.1 in another. I came across this problem when I was trying to create a Clonezilla backup of my machine. I obviously messed something up. My files on Zorin are still there but I cannot boot it. It will boot into Zorin just until it gets to the Lenovo screen with Zorin indicated at the bottom and then it just stays there. So i booted from usb and ran the repair and the following is what I got. Shure hope someone can help me out. I've done 1 months work on this, so I can get rib of Microsoft.
boot-repair-4ppa2081-zorin1 [20260626_0041]
============================= Boot Repair Summary ==============================
modprobe: FATAL: Module efivars not found in directory /lib/modules/6.17.0-20-generic
Recommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will reinstall the grub-efi of
nvme0n1p6,
using the following options: nvme0n1p1/boot/efi
Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file
/dev/nvme0n1p6 is 97 % full
** (org.gnome.Nautilus:30948): WARNING **: 00:41:45.099:
This app cannot work correctly if run as root (not even
with sudo). Consider running nautilus admin:/ instead.
** Message: 00:41:52.117: Connecting to org.freedesktop.Tracker3.Miner.Files
** (org.gnome.Nautilus:30948): WARNING **: 00:41:52.406: Unable to get contents of the bookmarks file: Error opening file /root/.gtk-bookmarks: No such file or directory
Mount /dev/nvme0n1p1 on /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9/boot/efi
Unhide GRUB boot menu in nvme0n1p6/etc/default/grub
=================== Reinstall the grub-efi of /dev/nvme0n1p6 ===================
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 grub-install --version
grub-install (GRUB) 2.12-1ubuntu7.3+zorin2
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 modprobe efivars
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 efibootmgr -v (filtered) before grub install
EFI variables are not supported on this system.
error trace:
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 uname -r
6.17.0-20-generic
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 grub-install --efi-directory=/boot/efi --target=x86_64-efi
Installing for x86_64-efi platform.
grub-install: warning: EFI variables cannot be set on this system.
grub-install: warning: You will have to complete the GRUB setup manually.
Installation finished. No error reported.
df /dev/nvme0n1p1
mv /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9/boot/efi/EFI/Boot/bootx64.efi /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9/boot/efi/EFI/Boot/bkpbootx64.efi
cp /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9/boot/efi/efi/ubuntu/grubx64.efi /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9/boot/efi/EFI/Boot/bootx64.efi
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 efibootmgr -v (filtered) after grub install
error trace:
Warning: NVram is locked (Zorin not found in efibootmgr).
chroot /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 update-grub
Sourcing file `/etc/default/grub'
Found theme: /usr/share/grub/themes/zorin/theme.txt
Found linux image: /boot/vmlinuz-7.1.1-070101-generic
Found initrd image: /boot/initrd.img-7.1.1-070101-generic
Found linux image: /boot/vmlinuz-6.17.0-35-generic
Found initrd image: /boot/initrd.img-6.17.0-35-generic
Found linux image: /boot/vmlinuz-6.17.0-29-generic
Found initrd image: /boot/initrd.img-6.17.0-29-generic
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Unhide GRUB boot menu in nvme0n1p6/boot/grub/grub.cfg
Boot successfully repaired.
Locked-NVram detected. Please do not forget to make your UEFI firmware boot on the Zorin OS 18.1 (18) entry (nvme0n1p1/efi/ubuntu/grubx64.efi file) !
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/nvme0n1.
=> Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sda.
=> No boot loader is installed in the MBR of /dev/sdb.
nvme0n1p1: _____________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/Boot/bkpbootx64.efi /efi/Boot/bootx64.efi
                   /efi/Boot/fbx64.efi /efi/Boot/mmx64.efi
                   /efi/ubuntu/fwupdx64.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
                   /efi/ubuntu/grub.cfg
                   /efi/Microsoft/Boot/SecureBootRecovery.efi
                   /efi/Microsoft/Boot/bootmgfw.efi
                   /efi/Microsoft/Boot/bootmgr.efi
nvme0n1p2: _____________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
nvme0n1p3: _____________________________________________________________________
File system:       ntfs
Boot sector type:  NTFS
Operating System:  Windows 8 or 10
Boot files:        /Windows/System32/winload.exe
nvme0n1p4: _____________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
nvme0n1p6: _____________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Zorin OS 18.1
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sda1: __________________________________________________________________________
File system:       ntfs
Boot sector type:  SYSLINUX 6.04
Boot sector info:  Syslinux looks at sector 35904 of /dev/sda1 for its
                   second stage. The integrity check of Syslinux failed.
Operating System:
Boot files:        /boot/grub/grub.cfg /syslinux.cfg /ldlinux.sys
sda2: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT16
Boot sector info:  According to the info in the boot sector, sda2 starts
                   at sector 0. But according to the info from fdisk,
                   sda2 starts at sector 31328136. According to the info
                   in the boot sector, sda2 has 0 sectors.
Operating System:
Boot files:        /efi/Boot/bootaa64.efi /efi/Boot/bootarm.efi
                   /efi/Boot/bootia32.efi /efi/Boot/bootx64.efi
                   /efi/Rufus/exfat_aa64.efi /efi/Rufus/exfat_arm.efi
                   /efi/Rufus/exfat_ia32.efi /efi/Rufus/exfat_x64.efi
                   /efi/Rufus/ntfs_aa64.efi /efi/Rufus/ntfs_arm.efi
                   /efi/Rufus/ntfs_ia32.efi /efi/Rufus/ntfs_x64.efi
sdb1: __________________________________________________________________________
File system:       vfat
Boot sector type:  -
Boot sector info:  According to the info in the boot sector, sdb1 starts
                   sdb1 starts at sector 32.
Operating System:
Boot files:
================================ 2 OS detected =================================
OS#1 (linux): Zorin OS 18.1 (18) on nvme0n1p6
OS#2 (windows): Windows 8 or 10 on nvme0n1p3
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: TigerLake-LP GT2 [Iris Xe Graphics] from Intel Corporation
Live-session OS is Zorin 64-bit (Zorin OS 18.1, noble, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: N34ET69W (1.69 )(1.69) from LENOVO
The firmware is EFI-compatible, and is set in EFI-mode for this live-session.
SecureBoot disabled (confirmed by mokutil).
BootCurrent: 001A
Timeout: 2 seconds
BootOrder: 0001,0000,0017,0018,0019,001A,0016,001B,001C,0010,0011,0002
Boot0000* Windows Boot Manager HD(1,GPT,e5c784ab-9cf8-42af-b0c5-1997bc5b1898,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000000000100000010000000040000007fff0400
Boot0001* Zorin OS HD(1,GPT,e5c784ab-9cf8-42af-b0c5-1997bc5b1898,0x800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0002* Linux-Firmware-Updater HD(1,GPT,e5c784ab-9cf8-42af-b0c5-1997bc5b1898,0x800,0x32000)/File(\EFI\ubuntu\fwupdx64.efi)
Boot0010 Other CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a35400)
Boot0011 Other HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f600)
Boot0012* IDER BOOT CDROM PciRoot(0x0)/Pci(0x14,0x0)/USB(11,1)
Boot0013* IDER BOOT Floppy PciRoot(0x0)/Pci(0x14,0x0)/USB(11,0)
Boot0014* ATA HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f6)
Boot0015* ATAPI CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
Boot0016* PXE BOOT VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot0017* USB CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot0018* USB FDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot0019* NVMe0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a400)
Boot001A* USB HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
Boot001B* LENOVO CLOUD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,ad38ccbbf7edf04d959cf42aa74d3650)/Uri(https://download.lenovo.com/pccbbs/cdeploy/efi/boot.efi)
Boot001C* ON-PREMISE VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,ad38ccbbf7edf04d959cf42aa74d3650)/Uri()
Boot001D Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot001E Boot Menu FvFile(126a762d-5758-4fca-8531-201a7f57f850)
Boot001F Asset Information FvFile(da465b87-a26f-4c12-b78a-0361428fa026)
Boot0020 Diagnostic Splash Screen FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0021 Lenovo Diagnostics FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
Boot0022 Regulatory Information FvFile(478c92a0-2622-42b7-a65d-5894169e4d24)
Boot0023 ThinkShield secure wipe FvFile(3593a0d5-bd52-43a0-808e-cbff5ece2477)
Boot0024 Startup Interrupt Menu FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
Boot0025 Rescue and Recovery FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
Boot0026 MEBx Hot Key FvFile(ac6fd56a-3d41-4efd-a1b9-870293811a28)
07e25dcaf57c776875f78fa36827c58e nvme0n1p1/Boot/bkpbootx64.efi
07e25dcaf57c776875f78fa36827c58e nvme0n1p1/Boot/bootx64.efi
39bc76ff6662f4fbe9aa116e4c997b41 nvme0n1p1/Boot/fbx64.efi
4ba5a5aad43c197e9fb58b76b404d287 nvme0n1p1/Boot/mmx64.efi
258e2247878acb0a2944052e26657e81 nvme0n1p1/ubuntu/fwupdx64.efi
94c7467f956700d44c5b4dcd3967535c nvme0n1p1/ubuntu/grubx64.efi
4ba5a5aad43c197e9fb58b76b404d287 nvme0n1p1/ubuntu/mmx64.efi
07e25dcaf57c776875f78fa36827c58e nvme0n1p1/ubuntu/shimx64.efi
5a064e6490c9ffdcf20fd19ca4756490 nvme0n1p1/Microsoft/Boot/SecureBootRecovery.efi
1cf36f92fb6122de4ae58a1c04c92eba nvme0n1p1/Microsoft/Boot/bootmgfw.efi
91045dc5c3a5f803db3622e507209b9d nvme0n1p1/Microsoft/Boot/bootmgr.efi
a144cdf68a1b4a080476756d3a7d387c sda2/Boot/bootaa64.efi
7ea85f012e6482faf17bff02cf37cd2e sda2/Boot/bootarm.efi
385a87935ec06de804e124c091da9ab4 sda2/Boot/bootia32.efi
9aa56ce6ecf80afd41e8c80ec10bd9be sda2/Boot/bootx64.efi
28a1075d3b15f99301551efed405e2df sda2/Rufus/exfat_aa64.efi
9c82ec49ffc461439f67a2f7e4a40a88 sda2/Rufus/exfat_arm.efi
0470bfa998830003c56100514b46f213 sda2/Rufus/exfat_ia32.efi
0a23436a13e727df5f8f5f2c211f7e9e sda2/Rufus/exfat_x64.efi
a03e27b0e7f2e03519166bf6b41f68c5 sda2/Rufus/ntfs_aa64.efi
2f31c70d3f4235476cd9ed6a18e13221 sda2/Rufus/ntfs_arm.efi
7e7e67c33ce9ff2961a4be4080d23352 sda2/Rufus/ntfs_ia32.efi
30c7e0752040cf5e31843d897a53e055 sda2/Rufus/ntfs_x64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, has-win, 2048 sectors * 512 bytes
sda : notGPT, no-BIOSboot, has-noESP, usb-disk, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes
sdb : notGPT, no-BIOSboot, has-noESP, liveusb, not-mmc, no-os, no-wind, 32 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
nvme0n1p3 : is-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB
nvme0n1p4 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, end-after-100GB
nvme0n1p6 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, end-after-100GB
sda2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sdb1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
Partitions info (2/3): _________________________________________________________
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat
nvme0n1p3 : isnotESP, part-has-no-fstab, no-nt, haswinload, no-recov-nor-hid, no-bmgr, notwinboot, ntfs
nvme0n1p4 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot, ntfs
nvme0n1p6 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4
sda2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat
sdb1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat
Partitions info (3/3): _________________________________________________________
nvme0n1p1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p3 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p4 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
nvme0n1p6 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1
sda2 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
sdb1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sdb
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk identifier: 19EF789C-3214-4EE9-8AF4-CC503C84ADB3
Start End Sectors Size Type
nvme0n1p1 2048 206847 204800 100M EFI System
nvme0n1p2 206848 239615 32768 16M Microsoft reserved
nvme0n1p3 239616 1579360255 1579120640 753G Microsoft basic data
nvme0n1p4 1998790656 2000406527 1615872 789M Windows recovery environment
nvme0n1p6 1579360256 1742942207 163581952 78G Linux filesystem
Partition table entries are not in disk order.
Disk sda: 14.94 GiB, 16041099264 bytes, 31330272 sectors
Disk identifier: 0x008acd14
Boot Start End Sectors Size Id Type
sda1 * 2048 31328103 31326056 14.9G 7 HPFS/NTFS/exFAT
sda2 31328136 31330214 2079 1M ef EFI (FAT-12/16/32)
Disk sdb: 1.88 GiB, 2013265920 bytes, 3932160 sectors
Disk identifier: 0x00000000
sdb1 32 3932159 3932128 1.9G 6 FAT16
parted -lm (filtered): _________________________________________________________
sda:16.0GB:scsi:512:512:msdos:Verbatim STORE N GO:;
1:1049kB:16.0GB:16.0GB:ntfs::boot;
2:16.0GB:16.0GB:1064kB:::esp;
sdb:2013MB:scsi:512:512:msdos:General UDisk:;
1:16.4kB:2013MB:2013MB:::;
nvme0n1:1024GB:nvme:512:512:gpt:ADATA LEGEND 700:;
1:1049kB:106MB:105MB:fat32:Basic data partition:boot, esp, no_automount;
2:106MB:123MB:16.8MB::Microsoft reserved partition:msftres, no_automount;
3:123MB:809GB:809GB:ntfs:Basic data partition:msftdata, no_automount;
6:809GB:892GB:83.8GB:ext4::;
4:1023GB:1024GB:827MB:ntfs::hidden, diag, no_automount;
Free space >10MiB: ______________________________________________________________
nvme0n1: 851046MiB:975972MiB:124926MiB
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
├─sda1 ntfs 28701C56701C2CD6 008acd14-01 Zorin OS 18_1 Core 64bit
└─sda2 vfat 06A0-0FA0 008acd14-02 UEFI_NTFS
sdb
└─sdb1 vfat
nvme0n1
├─nvme0n1p1 vfat DA8D-D772 e5c784ab-9cf8-42af-b0c5-1997bc5b1898 Basic data partition
├─nvme0n1p2 308ecace-987f-4c3f-8c25-e00e8fe986fb Microsoft reserved partition
├─nvme0n1p3 ntfs F05891C558918ACC 767ae8a3-9a5b-4a67-9671-e9dd3db423e3 Basic data partition
├─nvme0n1p4 ntfs 32283B1D283AE011 dd9911cf-7ce3-44f9-b333-ece733d6aff0
└─nvme0n1p6 ext4 1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 9bfdb197-ac78-47c0-9fa9-e5834a06ccb4
Mount points (filtered): _______________________________________________________
            Avail Use% Mounted on
/dev/nvme0n1p1 57.6M 40% /mnt/boot-sav/nvme0n1p1
/dev/nvme0n1p3 663.3G 12% /mnt/boot-sav/nvme0n1p3
/dev/nvme0n1p4 111.4M 86% /mnt/boot-sav/nvme0n1p4
/dev/nvme0n1p6 2.4G 92% /media/zorin/1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9
/dev/sda1 11.3G 25% /cdrom
/dev/sda2 116K 88% /mnt/boot-sav/sda2
/dev/sdb1 1.7G 8% /media/zorin/disk
efivarfs 118.5K 50% /sys/firmware/efi/efivars
Mount options (filtered): ______________________________________________________
/dev/nvme0n1p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
/dev/nvme0n1p3 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/nvme0n1p4 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/nvme0n1p6 ext4 rw,nosuid,nodev,relatime,errors=remount-ro
/dev/sda1 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sda2 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
/dev/sdb1 vfat rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro
=================== nvme0n1p1/efi/ubuntu/grub.cfg (filtered) ===================
search.fs_uuid 1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 root
set prefix=($root)'/boot/grub'
configfile $prefix/grub.cfg
=================== nvme0n1p6/boot/grub/grub.cfg (filtered) ====================
Zorin OS 1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9
Windows Boot Manager (on nvme0n1p1) osprober-efi-DA8D-D772
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
======================== nvme0n1p6/etc/fstab (filtered) ========================
/ was on /dev/nvme0n1p6 during installation
UUID=1c1a2172-30b2-4e1f-a6d8-753fefc7c2a9 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/nvme0n1p1 during installation
UUID=DA8D-D772 /boot/efi vfat umask=0077 0 1
==================== nvme0n1p6/etc/default/grub (filtered) =====================
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu
GRUB_CMDLINE_LINUX=""
GRUB_DISABLE_OS_PROBER=false
GRUB_THEME=/usr/share/grub/themes/zorin/theme.txt
GRUB_DISABLE_MEMTEST=true
================= nvme0n1p6: Location of files loaded by Grub ==================
       GiB - GB             File                                 Fragment(s)
        ?? = ??             boot/grub/grub.cfg                             1
779.301410675 = 836.768518144 boot/vmlinuz 3
756.339809418 = 812.113686528 boot/vmlinuz-6.17.0-29-generic 1
755.238250732 = 810.930896896 boot/vmlinuz-6.17.0-35-generic 1
779.301410675 = 836.768518144 boot/vmlinuz-7.1.1-070101-generic 3
755.238250732 = 810.930896896 boot/vmlinuz.old 1
814.391399384 = 874.446106624 boot/initrd.img 2
820.655700684 = 881.172348928 boot/initrd.img-6.17.0-29-generic 1
827.433589935 = 888.450052096 boot/initrd.img-6.17.0-35-generic 6
814.391399384 = 874.446106624 boot/initrd.img-7.1.1-070101-generic 2
827.433589935 = 888.450052096 boot/initrd.img.old 6
=================== nvme0n1p6: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 18123 May 17 2025 10_linux
-rwxr-xr-x 1 root root 43192 May 17 2025 10_linux_zfs
-rwxr-xr-x 1 root root 14513 May 17 2025 20_linux_xen
-rwxr-xr-x 1 root root 786 May 17 2025 25_bli
-rwxr-xr-x 1 root root 13120 May 17 2025 30_os-prober
-rwxr-xr-x 1 root root 1174 May 17 2025 30_uefi-firmware
-rwxr-xr-x 1 root root 722 Mar 13 03:54 35_fwupd
-rwxr-xr-x 1 root root 214 May 17 2025 40_custom
-rwxr-xr-x 1 root root 215 May 17 2025 41_custom
====================== sda1/boot/grub/grub.cfg (filtered) ======================
Try or Install Zorin OS
Try or Install Zorin OS (safe graphics)
Try or Install Zorin OS (modern NVIDIA drivers)
Power Off
========================= sda1/syslinux.cfg (filtered) =========================
DEFAULT loadconfig
LABEL loadconfig
CONFIG /isolinux/isolinux.cfg
APPEND /isolinux/
==================== sda1: Location of files loaded by Grub ====================
================== sda1: Location of files loaded by Syslinux ==================
        ?? = ??             syslinux.cfg
        ?? = ??             ldlinux.sys                                    1
Boot into Zorin from USB and access a terminal. Then try these steps in order:
Reinstall the kernel and rebuild initramfs
sudo apt update
sudo apt install --reinstall linux-image-$(uname -r)
sudo update-initramfs -u -k all
Verify the EFI boot partition is accessible
sudo fdisk -l
Look for a partition marked as "EFI System" (usually around 500 MB to 1 GB). Note its device name (e.g., /dev/sda1 ).
Reinstall GRUB to ensure it's properly configured for EFI:
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=ubuntu
sudo update-grub
I'll give it a shot and let you know. Thanks.
One caution before running those commands from the live USB: uname -r there can be the live session's kernel, not the broken install's kernel. I would first free some space on nvme0n1p6 if possible (Boot-Repair says it is 97% full), then chroot into the installed system before reinstalling kernels/initramfs or grub. The efivars message usually means the repair environment cannot write NVRAM; since your BootOrder already has a Zorin entry, also check the Lenovo firmware boot order and try the existing Zorin entry before changing more.
So I tried these commands after booting from USB and I got errors in every command. Would you like me to send you the errors I got from the commands. I did all this before reading your second message. Probably messed everything up even more. I don't understand a lot of what is said in your second message but I will look things up and learn. I really appreciate your help. Thanks again. I will let you know how things turn out once I get a chance to get this done.
You can try to boot to older kernel
  • Restart the PC and press Escape during boot to access the GRUB menu (may also be accessed with Shift)
  • Select "Advanced options for Zorin OS"
  • Here, you can see the available kernels to boot into. Choose the older one (without recovery option)
if it boot come back to us
WOW that worked. That is great. Before the older version there was a couple other version listed. Something like 17.0.11 or 17.1.1 or something. Should I get rid of these or what? When i look at the mainline kernels it show 16.17.0-35- generic running and it shows 17.0.11 and 17.1.1 installed.
Great,
Now run the following command
sudo apt update
sudo apt --fix-broken install
This is what I got.
$ sudo apt --fix-broken install
Reading package lists... Done
E: The package linux-image-unsigned-7.0.11-070011-generic needs to be reinstalled, but I can't find an archive for it.
So I looked at the Mainline Kernels and it shows as 7.0.11 as being installed. Here is the list of images
$ dpkg --list | grep linux-image
rc linux-image-6.17.0-20-generic 6.17.0-20.20~24.04.1 amd64 Signed kernel image generic
rc linux-image-6.17.0-23-generic 6.17.0-23.23~24.04.1 amd64 Signed kernel image generic
ii linux-image-6.17.0-29-generic 6.17.0-29.29~24.04.1 amd64 Signed kernel image generic
ii linux-image-6.17.0-35-generic 6.17.0-35.35~24.04.1 amd64 Signed kernel image generic
ii linux-image-generic-hwe-24.04 6.17.0-35.35~24.04.1 amd64 Generic Linux kernel image
iHR linux-image-unsigned-7.0.11-070011-generic 7.0.11-070011.202606011647 amd64 (no description available)
ii linux-image-unsigned-7.1.1-070101-generic 7.1.1-070101.202606191302 amd64 Linux kernel image for version 7.1.1
I found this link. Should I give this a shot to get rib of the half installed 7.0.11 package?
Because you removed the mainline repo, do that
sudo add-apt-repository ppa:cappelikan/ppa
sudo apt update
Did the 3 commands. This is what I got.Did you mean do the commands from the web site I sent you then do the 3 commands?
Didyou mean do the command from the wed site I sent you then do the 3 command?
Do that
sudo apt purge linux-image-unsigned-7.0.11-070011-generic
I don't know what you did but it seem you played a little bit too much with kernels...
Tried the command and got the following. Should I try the commands from the web site I sent you and try this command again?
OK so I followed the command in the link I sent you an I got rid of 7.0.11 which was flagged as half installed and which had the problem I then reboot and 7.1.1. which was also installed started no problem. I's like to thank you for your help which help me look for some solutions as well and we got it done. Thanks again.
