I'm using Zorin OS 6.2 Core. When I install Mongodb on my pc then I get errors. According to MongoDB docs, Import the public key used by the package management system wget -qO - https://www.mongodb.org/static/pgp/server-6.0.asc | sudo apt-key add -
then echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-6.0.list
then sudo apt-get update now installation partsudo apt-get install -y mongodb-org
Errors are showed :
Also, I try this command sudo apt-get check and sudo apt-get -f install but same error is showed.
Please
** send me any solution. I have to develop some website.
That should show the dependencies needed. You'll have to find a source of those packages and install them to satisfy the dependencies.
"The mongodb package provided by Ubuntu is not maintained by MongoDB Inc. and conflicts with the official mongodb-org package. If you have already installed the mongodb package on your Ubuntu system, you must first uninstall the mongodb package before proceeding with these instructions."
