umm hello so i downlouded it and put it in the usb stick but while downlouding it and wanted to try it my monitor got an error that said (input signal out of range) how to fix it?
Are you referring to running the Live USB?
Or have you installed Zorin OS?
If using LiveUSB - please reboot and boot from the LiveUSB and see if the problem persists across boots.
so hello there thanks for ur reply yes i checked it and its normal usb stick and i just installed zorin and i found out that the problem as i said it from my monitor it doesnt have the needed resolotion and i should downlouded zorin lite
Yes, you can try Zorin OS Lite and see if that is any different.
It sounds like you have an older Nvidia Card that is no longer supported.
