Hello guys,
Is there any more advanced progress bar when copying a file in Nautilus? Something similar to MS Windows?
Regards
Hello guys,
Regards
Can you clarify what More Advanced means?
I use USB every day to copy TV series on it and watch on TV, One of the biggest problem I have is, I sometimes forgot if the progress finished or not, and I remove the USB disk, and sometimes when I want to eject the disk it says it has unfinished job.
Finally, I need to watch it pop out of the file manager itself
I see. And since Nautilus progress bar only shows if you click on it, you may forget.
I use Nemo File Manager and in that, the Progressbar pops up in a modal window. It remains visible unless the user moves it
or closes it.
Nautilus has a Pie Chart progress indicator, which is easily overlooked.
Yes, his screenshot even shows it... But I overlooked it.
