SEP 2: After 3 separate font removal sessions that succeeded in freeing up approx 312MB, there’s still a whole bunch of non-latin fonts in my root folder: / usr/share/fonts/
I’m having a particular problem removing some 260 “Noto” fonts from the /truetype subdir
In Terminal, I can’t find the correct sudo command to remove them
In Synaptic, searching “noto” packages yields:
Package: fonts-noto
Installed ver: 20171026-2
Latest ver: [ditto]
Description: “metapackage to pull in all Noto fonts”
Here’s the problem:
“Mark for removal” or “Mark for complete removal” also requires removing
fonts-zorin-os-core
zorin-appearance
zorin-appearance-layouts-shell-core
zorin-appearance-layouts-support
zorin-auto-theme
zorin-desktop-session
zorin-desktop-themes
zorin-os-artwork
zorin-os-desktop
REMOVING THOSE FILES LOOKS LIKE A REALLY BAD IDEA!!
So am I stuck with 260 useless Noto fonts or what??
I am using Nemo File Manager. I suspect that in a different FM, you may get different results.
Which is part of why I use Nemo (Though SpaceFm is pretty good, too).
But, I elevated Nemo to Root. Then went to /usr/share/fonts
I hit the Search Button and typed “noto”
The results appeared in the FM as a List.
I then highlighted them all (click and drag, I had to hold the moouse button down for a minute) and once all highlighted, I could right click and select delete.
Cool! The Nemo method seems to have worked on the noto fonts, but I'll try this on some others. Are you being literal with the quotation marks and asterisks surrounding the name?
