I have it set to show mounted drives on the desktop.
They used to always be there, now when the PC wakes from suspend it takes a few minutes before they appear.
One is a windows smb share from the LAN, the other is a NTFS formatted local HDD. Both automount on startup via the fstab.
While the desktop shorcuts are mssing I can still access the folders through files.
Notes:
I have Files and Nemo installed. Each has it strengths and I use both.
I just upgraded to 18.1 core from 17.2 core. It went really smooth, I only had to set the sound back to hdmi.
This has been happening for awhile, aftet the last big update to 17.2 i believe, the upgrade to 18.1 hasn't changed it.
I would take a look here and also the link in it to 22.04. I know 18 is based on 24.04, but you never know:
In fact suspend mode in Linux have some problems (it broke my wifi since I installed Linux on my laptop), so I disable it and just use blank screen in power settings and all is fine.
You can do this
sudo nano /etc/systemd/sleep.conf
change the content file like this
[Sleep]
AllowSuspend=no
AllowHibernation=no
AllowSuspendThenHibernate=no
AllowHybridSleep=no
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
So give a try and tell us if it fix your problem...
system
Closed
August 6, 2026, 9:06am
4
