Mouse not waking computer
My computer does not like to wake with mouse. After many searches I found;
"sudo nano /sys/bus/usb/devices/usb7/power/wakeup" Choose the proper usb host, change to enable . I do this and it works fine for a while. Seems like maybe a hard reset, something is changing it back to disable! How can this happen? It takes a sudo command for me to change it, but the computer changes it at will!
This is an Asus Rampage III Extreme board.
Thanks for the help
Here are quite a few suggestions you can try to make the change persistent:
Thanks, looks like more reading
This is one crazy system! The mouse or usb bus is moving! Was 3 now 1
