/usr/bin/inxi: illegal option -- a
Error 7: One of the options you entered in your script parameters: -Faz
is not supported.The option may require extra arguments to work.
For supported options (and their arguments), check the help menu: inxi -h
[sudo] password for remus:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xserver-xorg-input-libinput : Depends: xserver-xorg-core (>= 2:1.18.99.901)
xserver-xorg-input-mtrack : Depends: xserver-xorg-core (>= 2:1.18.99.901)
Conflicts: xserver-xorg-input-multitouch but 1.0~rc3-1 is to be installed
xserver-xorg-input-multitouch : Depends: xserver-xorg-core (>= 2:1.18.99.901)
xserver-xorg-input-synaptics : Depends: xserver-xorg-core (>= 2:1.18.99.901)
E: Unable to correct problems, you have held broken packages.
sudo apt upgrade
had some interesting lines about my gpu
Setting up xserver-xorg-core-hwe-18.04 (2:1.20.8-2ubuntu2.2~18.04.5) ...
Setting up linux-firmware (1.173.20) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-80-generic
W: Possible missing firmware /lib/firmware/i915/tgl_dmc_ver2_04.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_33.0.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_33.0.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_33.0.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_33.0.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_33.0.0.bin for module i915
update-initramfs: Generating /boot/initrd.img-5.4.0-47-generic
That's a completely unrelated to your touchpad problem. I suggest starting a new thread regarding it - It's your video card... then again it could be related...
After updating your system, was it able to install the libraries?
$ sudo apt install xserver-xorg-input-libinput xserver-xorg-input-mtrack xserver-xorg-input-multitouch xserver-xorg-input-synaptics
Thanks for that, I did consider going with the beta but decided to stick with stable... It would be funny if all these problems went away if I was using the beta
I think I'll download V16 tomorrow if I still have no luck with V15.3
I get the same error as before after performing
sudo update
sudo upgrade
I know it sounds unreal, but many users had their problem in 15,3 solved in 16 beta.
I have been using 16 beta in my production environment without any major issue for a couple of months.
The most stable beta I have ever seen.
When I tested Zorin OS 15 Lite Beta, it was the same story. I never found a single bug. Maybe others did.
This signifies a "placeholder line" for a module waiting to be added to the kernel. It is not dangerous and often - updating the system resolves it when it brings a kernel update. It may show that a newer kernel may be needed for your machine.
Zorin OS comes with the HWE package by default, rather than the standard core package. HWE = Hardware Enablement. While this is often beneficial, at times HWE can conflict and xserver-sorg-core performs better. I usually go with xorg-core, myself.
xserver-xorg-input-libinput is already the newest version (0.29.0-1).
xserver-xorg-input-libinput set to manually installed.
xserver-xorg-input-mtrack : Conflicts: xserver-xorg-input-multitouch but 1.0~rc3-2 is to be installed
P.S. Zorin v16 beta boot up takes a long time, but im guessing thats been reported. And as a beta... not unexpected.
@remus
If your problem is solved, please tick box to mark the thread as solved. This way, the future visitors to this forum can find the solution easily.
