Mouse Pointer Speed Tanking after Suspend or on boot
I recently changed my mouse form a mouse to a trackball, and after I set the pointer speed in settings after a suspend the speed tanks. I then have to turn off the trackball and turn it back on for it to recover. It also does this sometime after boot up.
It is a Logitech Trackball Mouse with a USB transmitted and mouse as the reciever (Wirelesss). Would anyone have some help or had this problem before?
I am running Zorin OS 16.1 on an AMD Ryzen. Any help is appreciated.
Thanks so much
Drezin
Does this help?:
https://help.ubuntu.com/community/Logitech_Marblemouse_USB
From what I can tell this worked. Definatley better then it was. Have no idea what I did but thank you for your help.
Drezin
Glad you got sorted friend.
