Mouse touchpad lags and freeze
Hello Guys
Im having some problems with my keyboard mouse on my Legion 5.
Don't know why, but in this zorin 17 i notice a lot this freezing and lags.
Where i can start troubleshooting this kind of issue?
Thanks
Hi and welcome,
Are you using wayland ? If yes try to switch to x11 to see if that runs better. To do so sign of or reboot. When you are on the login screen you should see a wheel, click on it and login on xorg/x11.
Also what specs does the legion 5 have ?
Im using Wayland
CPU: AMD Ryzen 5 5600H (12) @ 4.28 z
GPU 1: NVIDIA GeForce RTX 3060 Mobi]
GPU 2: AMD Cezanne [Integrated]
Memory: 2.68 GiB / 13.50 GiB (20%)
Swap: 0 B / 2.00 GiB (0%)
I change to xorg/x11 i don't solve the issue.
In both start like normal speed mouse and after a few seconds or minutes, they start freeze and lag.
What nvidia driver do you use ?,
Im using
Change to 560 driver, and appear to not lag and freeze, let see if this was the problem or not.
I would have picked the 565 driver since 560 has alot of issues (suspend bug, games not launching and so on). But i am glad it is working now.
I change to 565 and stop the lag.
