This may be an Ubuntu thing as well but my Google searches for my issues have turned nothing up, hence the post.
My issue:
- Applications like System Monitor and Settings and others not remembering to open on Primary Monitor's desktop. Even after moving over to appropriate desktop, closing and re-opening.
My questions:
- I want to know how to enable an application to open on the same connected monitor's desktop, no matter what.
- I also want to know if it is possible to have an application similarly remember its position; either based on last closed position, or modifier-key exit, etc...
EDIT: To follow-on to original post, minimized applications also ALWAYS animate to the wrong 'Primary Monitor' that I set in 'Settings'. If using the image below for reference for instance, all the open windows on Display 2, will minimize to Display 1 - and when clicking on them to restore, I see the animation start all the way over on Display 1, finishing on Display 2. This seems wrong.
I have also used the Tweaks tool and have ensured that 'Static Workspaces' is enabled and set to '1'. I also set my 'Workspaces are set to span displays' option without success.
Thank you for any assistance. Looking for any advice.
Please refer to the image below for an idea of what I am talking about.
