soo i previously posted about this that my webcam isnt working.there is some progress the thing is that my webcam finally stared giving input on the gnome camera app after i downloaded it. it shows everything in the camera app but when i try to take a pic or record vid from webcam,it says it cant although its giving input.sidenote:my webcam also has a built in mic which also does not work
sidenote2:i dont ave a video card
ive tried many other camera apps and the result is same
Do you have very new, up-to-date hardware? If so, it might help you to use a newer kernel. You can install this with mainline.
The camera may still require permissions to be able to save images/recordings.
Can you please open a Terminal (Menu | Utilities | Terminal) and enter:
lsusb
and post back the results please
Bus 001 Device 007: ID 1b80:b412 Afatech MECHREV Gaming Mouse
Bus 001 Device 006: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Action MA-8910P
Bus 001 Device 009: ID 057e:2009 Nintendo Co., Ltd Switch Pro Controller
Bus 001 Device 004: ID 1b3f:2002 Generalplus Technology Inc. 808 Camera
Bus 001 Device 003: ID 413c:2107 Dell Computer Corp. KB212-B Quiet Key Keyboard
Bus 001 Device 008: ID 1a2c:8cf4 China Resource Semico Co., Ltd USB Gaming Keyboard
Bus 001 Device 002: ID 10d7:b012 CSR8510 A10
i have zorin updated
Is it better now? Can you take pictures or record videos with your cam now?
Your camera appears to work on some machines and not others with some being detected and others malfunctioning:
You have to be aware your machine was designed to work with that other OS. I recommend that you purchase a cheap usb powered webcam if you have enough ports spare. I've never had an issue with logitech cams or if you want a GNU/Linux dedicated camera:
No bro need help still
I cant afford to buy a new cam,this also was bought from temu dirt cheap pls any solution to fix this
Can you please give us information about your desktop/notebook? Brand and model and if possible, if Desktop, motherboard make and model.
bro i live in pakistan ans i recently shifted from win11 to zorin.i have rtx3060, 12400f, 16gbddr4 local, ease motherboard.kinda low quality not a huge company and its cheap
this ![]()
I've trawled through the devices on that Linux hardware link I sent you and onky major brands are mentioned and even then mist only get detected which means the hardware isidentified but will not work. Sorry to say there is no way to resolve this issue.
