Computer fan is too noisy even while any program does not run. While i was a windows user, i played rdr2. when i played rdr2, fan works like now. what is the problem and how can i fix it?
Hi, welcome. Please launch a terminal from the main application menu, and run:
sudo lshw
This will tell us more about the computer you're on. Also, when pasting the output of the command, which will be quite lengthy, please use the preformatted text button, or wrap it around triple backticks (`):
