So, basically, I've got this Hp thin client which used to run on windows embedded, but I wanted to repurpose it, so i installed Zorin Lite, but, when it booted up, the cursor was HUGE, and the icons from the apps menu where very small, and just seems like everything is the wrong shape and resolution, but i can't change anything, I tried changing the cursor size, and i couldn't because it was the smallest one available.
Also... One day, I booted the thin client up, just as I use to do, but to my astonishment, everything was ok, the cursor was the correct size, and everything running smoothly. I turned off the computer, and when I checked the next day, it was all wrong AGAIN!!
