hey guy I'm Harisudhan and i installed zorin os and dual booted it with windows and everything is working fine, But i don't know why my microphone(even when connected to my earphone) is not working but it is working in windows tho please help me guys
As 337harvey has mentioned, can you tell us what version and flavour of ZorinOS you are using e.g. Z15.3 Core, Lite etc or maybe Z16 Core Beta.
Also tell us about your machine and its sound card.
The first thing to look at is Zorin Settings>Sound and see if the mic appears there.
Second thing I would do is run Alsamixer from terminal and see if mic is muted (i.e. showing "M) and unmute it.
(I think that is what 337harvey meant by "ulsa mixer", but is a typo in his post)
See this: Internal microphone not working on new install - #3 by zabadabadoo
Also you will find several other threads re sound issues if you do a search on this forum.
The terminal version should be included as standard with ZorinOS whereas the UI version would have to be installed. I have found the terminal version more than adequate and the UI version does no more.
i am using z16.0core i guess it's the latest one(19.8.21)
and can you please tell me how to find about my sound card
You can use the terminal command:
sudo lspci -v
Look for "Audio device" listed.
