that's exactly what
Here, I have replied on this issue, steps on turning off the AER
Does this procedure fix problems and hangs during installation?
Maybe the usb stick was bad or with corrupted files?
I am sorry. I thought when you acknowledged the link, you saw it listed possible solutions. I should have clarified that.
It listed these two suggestions:
sudo nano /etc/default/grub- Edit grub. Add
pci=noaerat the end ofGRUB_CMDLINE_LINUX_DEFAULT. Line will be like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=noaer" - Hit ctrl+x to exit, then hit the
ykey to say yes to save, then theenterkey to save as current configuration. sudo update-grub- Reboot now
Suggestion Two: Identical to the above, but replace pci=noaer with pci=nommconf
I was able to solve my problem
I had to install zorin os on another laptop and modify the grub on it and then put the disk in my laptop again and the system works great
thanks
