I'm forced to use a generic graphics driver right now.
I'm at the very end of reloading Zorin and all my apps, but when I rebooted for the last time, I got Windows 95 graphics.
"Additional Drivers" app isn't giving me the option to download Nvidia drivers. The list of drivers is grayed out with no explanation or advice about how to access them. The app has been like that since I reloaded Zorin yesterday. I expected maybe the problem could be corrected on its own, that maybe the servers were down. If so, they still haven't recovered.
Is there a simple way to correct the "Additional Drivers" issue?
Or could I at least fix the graphics issue for now?
What I'm trying:
-I've tried changing the sources on the AD app's lists. I have Canonical Partners checked, and have all the Zorinos sources checked (but not for the source code).
-I downloaded the drivers from Nvidia's website, but it's a windows package.
-I also plugged my Zorin thumb drive back in and found the video drivers there. But "Additional Drivers" won't look for them there.
-I might try to unload and reload the AD app. But again, that has to be done from the command line.
By myself, I likely won't get any of those done before you can help. It's probably something very simple, but if it's the servers, I'm screwed.
