My screen doesn't receive signal after loading up zorin os 16 from bootable drive
Try holding or tapping Left shift Key vigorously or tapping esc like your life depends on it.
Try the shift key, uefi has escape key
I tapped esc rapidly throughout but i still have this error
whereas left shift hold n tap i am brought to this normal screen
Oh... You have not installed Zorin OS. That is why.
What does Try Zorin (Safe Graphics) yield?
IT loads
Are you trying to install?
Once the With Safe Graphics option loads, are you able to run the installer?
