My Surface Earbuds don't connect to my laptop anymore
I had windows and installed zorin on my main work computer. Small annoying problem though. Now my Surface Earbuds are having connectivity issues. It says it connects, but for some reason I can't make it my output. So I can't hear anything from it.
The Surface Earbuds are a Microsoft product. And I imagine I need some driver to make it work. But what do I do? I can't find anything that works online.
The bluetooth works. I just tested it on a speaker. It just doesn't work on the Surface Earbuds. What should I do to get it to work?
Let me know if you need any specs.
Some report success with using Surface products by using the Surface Linux Kernel:
