Digital Mic selected
My earphones mic selected
Tried every possible thing on internet since last night
here's a screenshot of my alsamixer setting
To get bluetooth headset mic i think you need pipewire
I also had the same problem
Just use the commands in the terminal step by step
sudo apt install pipewire
sudo apt install pipewire-audio-client-libraries
systemctl — user daemon-reload
systemctl — user — now disable pulseaudio.service pulseaudio.socket
systemctl — user — now enable pipewire pipewire-pulse
systemctl — user mask pulseaudio
systemctl — user — now enable pipewire-media-session.service
then reboot and see if the bluetooth mic shows up
try this
isn't it a bug of Ubuntu/Zorin which should be fixed ?
okaaay I will manage my life with laptop sound ![]()
