so somehow my texture pack is broken my icons look like this and some of my windows are white and some are dark i have no idea why
my terminal is also like this
so how can i reset it to the default zorin appearance
As far as the icons go they look like accessibility icons/theme has been selected. Go to Settings | Accessibility and see if any settings have been turned on there. If not it might just need a reinstall of zorin-desktop.
Those are definitely the high contrast icon set.
@DARKLORD
Can you specify what is wrong with how your terminal looks?
What exactly did You before that happened?
