I just installed my sql using the terminal and after setting the password it is giving an error after typing mysql in the terminal.
After setting the passcode, typing mysql in the terminal will give you a error.
You need to type mysql -u (username) -p
then the passcode (it is default root if you left it blank)
That Should Give You access to the Local Server ![]()
Oh... Yeah its like a basic Mistake I made, thank you for your time.
