Sometimes when i start the system, Nautilus reverts to default double click to open files, even if i previously set one click. Any idea why it happen? Thank you
You may have a script that an installed app placed in ~/.config that is interferring with your saved settings.
You can test this with:
mv ~/.config ~/.config-bk
This will backup all your personalized configurations and create a new Default Config directory.
Reboot and launch Nautilus. Set your preferences up as you want them to be including Single Click.
Test for a while and see if the reversion stops happening.
ok,thank you
