In the system monitor disk read it starts from 1gb to 100gb.
once it reaches upto 110gb then it works fine for the rest of session until next reboot.
I dont know what its reading
how to stop this behaviour
anyone?
I'm not an expert on this but I won't worry about that value, probably it's just a total that tells you how much memory has been used till now to read the disk content. And maybe it's also a normal/common value. Did you try doing a search about this?
I tried. With memory map I can see its reading .cache/tracker/meta.db of 110 Gb and until its done reading it wont open..
Googling says disable tracker.
But I have other machines with ZOS16
This dont happen there.
Do you have other extensions for it? By default I have that Sushi, that Provides a system to quickly view different files
, then other 2 I don't know, maybe I'll try them.
I also checked better right-click options menu on my Nautilus (always on System Monitor), on Change priority it should be set to Normal by default, I had scary slowdowns when I changed this option on Windows and I'm not sure what can do on Zorin. I wonder if it would also be safe to see if Stop can fix, it should simply pause any process ran by Nautilus until you click Continue.
