Need a PDF printer
hi, Can anybody suggest an app to create PDF files from an Libre Office Calc spreadsheet, i.e. an app to create PDF prints. It's for Zorin 15.3?
Thanks
Update:- The solution is that in Libre Office Calc, under the "File" menu, there is an option to "export as PDF". This works quite well.
Strange, can't any printer capable of printing graphics, be able to print PDF's? You just want to print PDF's on normal paper right?
Maybe that is what you are looking for?
Hi 009jim and welcome to the forum. Are you asking about an actual printer or a program that will let you print PDF files? If you are looking for a program that will print PDF files then Okular will do that just fine. I was having problems finding a way to print PDFs until I found Okular. Okular can read almost any kind of text file and allow you to print it.
thanks, I've edited my question to be more clear
I think that the OP figured that out.
Read:
Oh, I did not know that. Lol :sweat_smile:
