my SSD with windows 10 is dying, and I ordered a new ssd. I want to transfer my current Zorin installation to the new SSD, and use use the old SSD used for Zorin for windows.
how can I transfer zorin to the new SSD?
If you download the rescuezilla image, it will allow you to backup the partitions. When the drive arrives, you can restore the partitions and everything will be as you have it now. There are other processes that you can do (y-ppa-manager, apt & dpkg to backup the installed applications and save the home directory) but are redundant to rescuezilla.
thank you!
