#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
/* Here we add the main systems for reverse-engineering */
int fazer_engenharia_reversa (int argc, char *argv[]) {
void fazer_raw_hacking_on_operating_systems (int argc, int *argv[0])
char raw_bruteforce_on_passwords = sha256 (int argc, int *argc[0]) {
scanf("%s", "Opa... encontrei um malware no sistema operacional... Quer fazer a engenharia reversa?(S/N): Se Sim... iniciando o prompt de engenharia reversa");
printf("Malware Encontrado... Iniciando modo de engenharia reversa... Reverse Engineering Mode Desengaging...");
return 0;
echo: "NL1SO2PR3SV4KiPOsARgMUsOWtHJkPLosVBcNIPtus" | sha256sums -c "NL1SO2PR3SV4KiPOsARgMUsOWtHJkPLosVBcNIPtus".txt
int main(int argc, char *argv[]) {
verificar_por_malware(int argc, char argv[1]) {
const char usleep(10); /* Deixar o usleep em 10 milisegundos para evitar desgaste em um único core da CPU */
scanf("%s", "Opa... encontrei um malware enxuto no sistema operacional... deseja iniciar engenharia reversa? (Y/N): ");
print("Limpando o malware do sistema operacional");
return 1;
I have some issues but a midway part of the syntax is right, however there are a couple errors that needs to be fixed for it to work and my intention here is about reverse engineering as you could see
