Need help with Bluetooth connectivity on Zorin OS 17 Pro
Hello everyone,
I am reaching out to seek assistance regarding an issue I'm experiencing with my Zorin OS 17 Pro installation. Despite my efforts, I have been unable to get the Bluetooth functionality to work properly. This is particularly frustrating for me as Bluetooth is essential for my workflow.
I have diligently followed various tutorials both from online sources and within the Zorin OS forum itself, but unfortunately, none of the suggested solutions have yielded success. As a paying user of the Pro version, it is disheartening to encounter such difficulties that impede my ability to fully utilize the system's capabilities.
I am sincerely reaching out to the community in the hopes that someone may have encountered a similar issue or possesses the expertise to provide guidance on resolving this matter. Any assistance or advice would be greatly appreciated.
Thank you in advance for your help.
Best regards,
Ermesson Rodrigues
Infos:
ermesson@deskduh:~$ hciconfig
hci0:	Type: Primary  Bus: USB
	BD Address: 06:6F:0E:00:1B:65  ACL MTU: 0:0  SCO MTU: 0:0
	DOWN
	RX bytes:165 acl:0 sco:0 events:9 errors:0
	TX bytes:273 acl:0 sco:0 commands:10 errors:0
ermesson@deskduh:~$ rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
ermesson@deskduh:~$
ermesson@deskduh:~$ sudo service bluetooth status
[sudo] senha para ermesson:
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2024-03-21 10:00:14 -03; 22h ago
       Docs: man:bluetoothd(8)
   Main PID: 685 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18927)
     Memory: 1.8M
        CPU: 34ms
     CGroup: /system.slice/bluetooth.service
             └─685 /usr/lib/bluetooth/bluetoothd
mar 21 10:00:13 deskduh systemd[1]: Starting Bluetooth service...
mar 21 10:00:14 deskduh bluetoothd[685]: Bluetooth daemon 5.64
mar 21 10:00:14 deskduh bluetoothd[685]: Starting SDP server
mar 21 10:00:14 deskduh systemd[1]: Started Bluetooth service.
mar 21 10:00:14 deskduh bluetoothd[685]: Bluetooth management interface 1.22 initialized
ermesson@deskduh:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 33fa:0010  USB2.0-BT
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0c45:5004 Microdia Redragon Mitra RGB Keyboard
Bus 001 Device 003: ID 04d9:fc30 Holtek Semiconductor, Inc. Gaming Mouse [Redragon M711]
Bus 001 Device 002: ID 0525:a4b1 Netchip Technology, Inc. nuroum V11
ermesson@deskduh:~$ lsmod | grep bluetooth
bluetooth            1081344  13 btrtl,btmtk,btintel,btbcm,bnep,btusb
ecdh_generic           16384  1 bluetooth
Hi and welcome to the forum.
Did you come to ZorinOS from Windows?
If true, did you disable Fast Start in Windows and disable Secure Boot in your BIOS?
Can you tell us a bit about your machine hardware and particularly your wifi and bluetooth adapter.
After you installed Z17, did you check Software Updater > Additional Drivers tab for drivers etc?
Please open a Terminal (Menu | Utilities | Terminal) and enter:
sudo lsusb |grep Bluetooth
and post back the results please.
ermesson@deskduh:~$ sudo lsusb |grep Bluetooth
ermesson@deskduh:~$
no have results
ermesson@deskduh:~$ neofetch
        `osssssssssssssssssssso`           ermesson@deskduh
       .osssssssssssssssssssssso.          ----------------
      .+oooooooooooooooooooooooo+.         OS: Zorin OS 17.1 x86_64
                                           Kernel: 6.5.0-26-generic
                                           Uptime: 4 mins
  `::::::::::::::::::::::.         .:`     Packages: 2049 (dpkg), 29 (flatpak),
 `+ssssssssssssssssss+:.`     `.:+ssso`    Shell: bash 5.1.16
.ossssssssssssssso/.       `-+ossssssso.   Resolution: 2560x1080
ssssssssssssso/-`      `-/osssssssssssss   DE: GNOME 43.9
.ossssssso/-`      .-/ossssssssssssssso.   WM: Mutter
 `+sss+:.      `.:+ssssssssssssssssss+`    WM Theme: ZorinBlue-Dark
  `:.         .::::::::::::::::::::::`     Theme: ZorinBlue-Dark [GTK2/3]
                                           Icons: ZorinBlue-Dark [GTK2/3]
                                           Terminal: gnome-terminal
      .+oooooooooooooooooooooooo+.         CPU: AMD Ryzen 5 3500X (6) @ 3.600GH
       -osssssssssssssssssssssso-          GPU: AMD ATI Radeon RX 5500/5500M /
        `osssssssssssssssssssso`           Memory: 2374MiB / 15899MiB
ermesson@deskduh:~$
Secureboot = off
Fastboot = NormalBoot (fast off)
type or paste code here
Okay, try:
sudo lshw -C network
and post back the results.
ermesson@deskduh:~$ sudo lshw -C network
  *-network
       descrição: Ethernet interface
       produto: I211 Gigabit Network Connection
       fabricante: Intel Corporation
       ID físico: 0
       informações do barramento: pci@0000:03:00.0
       nome lógico: enp3s0
       versão: 03
       serial: 3c:7c:3f:21:2a:f9
       tamanho: 1Gbit/s
       capacidade: 1Gbit/s
       largura: 32 bits
       clock: 33MHz
       capacidades: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuração: autonegotiation=on broadcast=yes driver=igb driverversion=6.5.0-26-generic duplex=full firmware=0. 6-1 ip=192.168.3.2 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       recursos: irq:34 memória:fcc00000-fcc1ffff porta de E/S:e000(tamanho=32) memória:fcc20000-fcc23fff
ermesson@deskduh:~$
*-network
ID físico: 0
nome lógico: enp3s0
versão: 03
tamanho: 1Gbit/s
capacidade: 1Gbit/s
largura: 32 bits
clock: 33MHz
ermesson@deskduh:~$
  *-network
       ID físico: 0
       nome lógico: enp3s0
       versão: 03
       tamanho: 1Gbit/s
       capacidade: 1Gbit/s
       largura: 32 bits
       clock: 33MHz
For some reason I can't post the result from the terminal, here's an image.
OK, usually bluetooth uses usb. Ensure Bluetooth in BIOS is active/key combo has it switched on.
sudo lshw -C usb
or just
lsusb
No have infos of active or not in my BIOS
ermesson@deskduh:~$ sudo lshw -C usb
ermesson@deskduh:~$
Gday @ermesson ,
Please Ignore the PM's from myself.
It seems the system had an ooppsy :slight_smile:
Sorry for any inconvenience.
Zorin Forum Community.
Gday @ermesson ,
Please keep us informed on your progress.
It looks like it's all working, is it a Linux compatible usb BT?
Have you used the usb BT device before on a Linux system?
You may see some errors in
cat /var/log/syslog
