Hi so I get quite a few errors since installing zorin and I am aware that most of them were here before the zorin install but I feel like now I am able to fix some of these with your help. I am not very familiar with Linux.
The main issue is that at start up screen I get this failed to parse error.
~$ dmesg --level=err
[ 0.110655] x86/cpu: SGX disabled by BIOS.
[ 0.489893] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[ 0.492216] pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
[ 0.977036] wmi: Failed to parse WDG method
[42343.643344] ACPI Error: Thread 2222505728 cannot release Mutex [ECMX] acquired by thread 3682090752 (20210730/exmutex-378)
[42343.643354] ACPI Error: Aborting method _SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20210730/psparse-529)
[77105.801104] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[83313.156406] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[83317.248765] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[83321.660988] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[83325.753168] usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
[83325.753262] usb usb2-port1: unable to enumerate USB device
$ sudo apt-get install --reinstall --fix-missing
Reading package lists... Done
Building dependency tree
linux-headers-5.14.0-1052-oem linux-headers-5.15.0-48-generic
linux-hwe-5.15-headers-5.15.0-48 linux-image-5.14.0-1052-oem
linux-image-5.15.0-48-generic linux-modules-5.14.0-1052-oem
linux-modules-5.15.0-48-generic linux-modules-extra-5.15.0-48-generic
linux-oem-5.14-headers-5.14.0-1052
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Rebooting should be sufficient. IF you see the errors prior to the Zorin Splash screen, you will know they are present.
AE and SGX disabled may be present but can be safely ignored as long as your system boots and runs normally.
Unless you are feeling particularly picky about seeing the errors at boot; they can be ignored.
They relate to:
"Default says I should do this, but this hardware says I cannot do this, so instead I will do that."
I still get the AE_ALREADY_EXISTS error on every reboot.
It bugs me.
Intellectually, I know it is meaningless and I know that there are plenty of "errors" that pop up that the system overrides and executes a different way that I don't see.
Even so, it bugs me seeing any error. I feel compelled to fix it. Even when it isn't broken to be fixed...
As long as everything boots and runs normally... You should be fine. It's one of those things where hardware was built for Windows and we are running Linux.
Yeah, I guess I like things tidy... Hence why these little errors bug me. I am just surprised that for example there is no fingerprint sensor that works with my computer. I though the computer I own is pretty common and that Linux would have something like it in place. Perhaps it is best to keep windows on the laptop and linux? Thanks again for your help.
This is a performance or functionality error, rather than a bypassed system warning error that can be ignored.
Fingerprint sensor is one of a few things that admittedly need better support on Linux. 4k monitors is another.
I looked up XPS-13-7390-2-in-1 and it certainly does list the camera and the Fingerprint reader as unsupported.
It may seem odd, since Dell offers computers pre-installed with Ubuntu. But remember; Dell does not make the camera or reader. They buy them from another manufacturer then assemble the computer.
