I have quanundrum I am hoping someone can help me with. I am running Zorin 17.2 on a 2012 MacBook Pro and I installed WINE 64 bit on it. After the install on the terminal at some point a msg came up saying I should install WINE32 because more applications use it or something to that extent, so I want to install. I hit yes and then it proceeeded to uninstall a bunch of stuff and then install Wine 32. Ok Fine. I was a bit concerned because it seemed like it was uninstalling Zorin stuff too but it was working ok….until the next time I restarted he computer. To my surprise it didn’t boot but went to a terminal command line asking for my login and password. Even after putting that in it stayed in TTY1. I went to try to fix it by booting from my original install thumb drive, and when I ran a boot repair it said NVRam locked. Can anyone tell me what may have happened and how to fix it? I don’t understand much about the highly technical aspects of computers but it seems like some how the Wine 32 thing messed up my Grub??
Thank you so much for your timely response and help…it is appreciated!
Yeah it makes sense that it replaced it with 32 bit. I thought it would just be contained in the app and not hose my whole OS, so when the prompt came up I thought “ok that’s odd but it shouldn’t hurt anything”…whoops! I won’t do that again.
I have followed your instructions and put in the commands, and they worked until #3 I get a red E and it says “ unable to locate package Zorin-os-desktop” and unable to to locate package grub-pc-bin-grub-efi-amd64-bin.” Tried it twice in case I typo’d or something. Any thoughts?
Thanks again.
Ok, ty….you’re right it says i386…
ok, just typed the dpkg remove command and it says “Cannot remove architecture I386 currently in use by the database.”
Yeah that was a lot, appreciate the clarification….OK it says E: removing the essential system critical packages is not permitted. This might break the system.
Question for you: so The last time I installed the wind 32 it uninstalled the 64, Would it do the same (uninstall the 32 and install 64 over it) if I try to reinstall the 64?
Lol, right? My computer hasn’t exactly been cooperating so far. Good to know it may be an option…
Ok, I did your last command and it looks like it is working now… it says the following packages will be removed and then It lists a whole bunch of things with numbers i386….Then it says the following new packages will Will be installed something about libdecor 00 Cairo and a number of other things…the last one says Wine64 (so I take it that’s a good sign🤞🏻) and then it says after this operation 264 MB this disk space will be free do you want to continue yes or no? Assuming yes?
Oh and just so you know, this is a dual boot computer. I have a Mac OS on a separate partition. So far what I have done has not affected it, but just to be cautious, this operation you’re asking to do would that affect the other partition as well or just the Linux partition?
Ok, it removed a bunch of stuff and set up some stuff and then it says:
Processing triggers for wine 6.0.3~repack-1
Processing triggers for Libc-bin 2.35…
Processing triggers for man-db (2.10.2-1
and then the root@…(myname)MacBook:~# with the blinking cursor on the following line.
