Needing help installing hyprland
I'm using zorin OS 17.2, and I discovered hyprland just out of curiosity and I just couldn't get a straightforward way to install it onto Ubuntu 22.04 LTS when I tried compiling it, it complained about some c++ stuff any tips
(Oh and btw sorry for terrible English)
The short answer is: You need a cutting edge rolling release distro to use Hyprland.
It will not work on Ubuntu or Zorin OS. If you can get it installed; Expect breakage.
Aight it's distro hopping time
(Edit I'm going to try arch without using archinstall wish me luck on that I don't fall onto the arch rabbit hole)
