Network adapter not detected
I have a killer wifi-7 BE 1750i (BE201 NGW) Its not picked up by Zorin but it is in Ubuntu 24.04. Is it too modern or is there a work around?
Try to boot with another kernel for testing. In grub menu at "Advanced options for Zorin" select an older kernel.
I'm not sure if that site can help you which recommends to download the firmware (as you wrote that it works in ubuntu 24):
https://community.intel.com/t5/Wireless/Intel-Wi-Fi-7-BE201-firmware-missing-on-Ubuntu-Linux-24-04-LTS/m-p/1723396#M62055
There were problems with iwlwifi drivers recently caused by kernel updates.
Could You post the Output of the Command sudo lshw -C network please? Are Secure Boot and Fast Boot in BIOS disabled? If Windows is installed: Is Fast Start-Up in Windows disabled?
Thanks to AI it helped me install the latest firmware via terminal and everything's working. :grinning_face:
