Hello, my network adapter sometimes doesn't load when I boot up my system. I log in and it doesn't connect to the Wi-Fi and it says No network adapter found. A reboot fixes it most of the time, but sometimes I have to reboot more than once to get it to work. Is there a way to fix this?
Hello, I am not the expert here, probably you may hear from one soon. However, this seems to be an ongoing perennial pain with Ubuntu, I have had it on and off for around 3 years in Zorin and previously with Ubuntu also.
I am following this in case someone has a solution other than constant reboot.
try a different driver for the network hardware, I am new to linux and ubuntu but this would be something I would try if I was in the same situation.
There are a few suggestions here:
Can I ask is Software Updater settings for Zorin Software set to "Main Server" and have you looked at Additional Drivers tab.
No it's using a server for my country
You are generally better off changing to "Main Server".
