Hi, I am having major issues with internet speed. I have really quick internet which ran fine when using ubuntu, but after installing Zorin 16 Pro it has dropped to less than 3 mb/s. The settings say 300-400 mbs, but that isn't correct at all. I have tried replugging in my router and modem, but that didn't work. I am at a complete loss, running Zorin OS 16, Surface Laptop 3 15", specs below.
Major Issue, Do You have a 5ghz Router?
Yep, it's pretty recently bought and has been running fine. I have a decent connection within 10 feet, but after this OS install anything farther drops as far as 1b.
I've already dealt with the power saving issue, so there hasn't been much of a change. It seems to go up and down, half the time the speed test completely times out.
I've used this specific laptop and never had issues when it was running windows or Ubuntu, it only started after Zorin.
So, the tutorial didn't help?
Nope, no change.
After the fix try a reboot ![]()
I already did.
Then there can be a lot of Reasons!
Try these :-
https://www.codegrepper.com/code-examples/shell/slow+internet+wifi+speed+on+ubuntu+18.04
None of these solutions helped either D: I've tried just about everything.
Have you tried running LinSSID to see if there are any channel clashes with neighbour's wifi?
