Changelog: VeraCrypt - Free Open source disk encryption with strong security for the Paranoid
Linux:
Add UI language support using installed XML files. Language is automatically detected using "LANG" environment variable
Compatiblity with with pam_tmpdir.
Display icon in notification area on Ubuntu 18.04 and newer (contibuted by https://unit193.net/).
Add CLI switch (--size=max) and UI option to give a file container all available free space on the disk where it is created.
Return error if unknown filesystem value specified in CLI --filesystem switch instead of silently skipping filesystem creation.
Under ZorinOS 16 now we have a proper tray Icon when VC is started and listening in background.
Awesome. Perhaps we should Tag the ZorinGroup to review this:
@AZorin and @zorink
mine doesn't work after installation. it apears in start menu but nothing happens when i try to start it. also don't know how to uninstall it. it was the package for ubuntu 21.0
ZorinOS 16 is based on ubuntu 20.04, so i have choosen the Version that is recommended for ubuntu 20.04.
Then the uninstall problem:
my system offers minimum two ways of uninstalling veracrypt
via terminal by sudo apt-get remove veracrypt
via Synaptic (can be installed via sudo apt-get install synaptic from the ubuntu repos)
system
closed
23 March 2022 08:48
#5
