Nextcloud not running with Zorin OS 16
Hi,
I recently installed Zorin OS 16 Pro on my laptop and it is running quite well, expect that nextcloud desktop is not running. It starts and the icon shows up in the system tray, then it disappears. I tried to look for error message in the log (nothing) or starting nextcloud from the terminal. The later just says "Aborted"...
Any help would be appreciated.
Have you installed the nextcloud-desktop app via snap / flatpak?
Had problems with nextcloud under Zorin 16 too until i completely removed every snap-stuff and used the following
sudo add-apt-repository ppa:nextcloud-devs/client
sudo apt update
sudo apt install nextcloud-desktop
maybe/hope it works for you either
