I'm getting an error message when trying to mount via command line a NAS share via NFS:
XXX@XXXX-ThinkPad-P50:~$ sudo mount -t nfs 192.168.68.61:/Volume1/Backups /mnt/Pika
mount: /mnt/Pika: bad option; for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount.<type> helper program.
XXXarcs@XXXX-ThinkPad-P50:~$
Haven't run across this one, seemed to have worked on my desktop running same Zorin system.
Here's what I did as a work around in case anyone else runs into this problem and comes looking for the solution here:
Created a script (mountall.sh) in /etc/init.d/:
#!/bin/bash
mount -r NFSSERVER-priv:/vol/vol1_isp/eshowcase/sites /var/www
mount NFSSERVER-priv:/vol/vol1_isp/vusers /var/users
Make the system aware of the new script:
update-rc.d mountall.sh defaults
The option “defaults” puts a link to start mountall.sh in run levels 2, 3, 4 and 5. (and puts a link to stop mountall.sh into 0, 1 and 6.)
Chmod the file to be executable
chmod +x mountall.sh
Now when you init 6 you should have your mount points. Also a good idea to make a "comment" in your fstab so people know where everything is actually being mounted from as that will be the first place they'll look.
I was pleased to see digital ocean. During lockdown the LinuxUserGroup co-ordinator built a Jitsi meet server on a notebook that was hosted by digital ocean during lockdown.
