I am running Zorin OS on an Infinix INBook X1 Slim (Intel Core i3 10th Gen / Ice Lake-LP) and am experiencing a persistent issue where there is no audio output from the built-in speakers (and microphone issues).
The system detects the sound card properly—under Sound Settings, the output device shows up as Speaker - Ice Lake-LP Smart Sound Technology Audio Controller , and pavucontrol confirms the profile is active and set to Stereo Output + Stereo Input at 100% (0 dB). However, no sound comes through when playing media.
ALSA & PulseAudio/PipeWire Checks: Verified levels in alsamixer and pavucontrol . Unmuted channels and ensured the output isn't stuck on Dummy Output.
Driver Quirk Configuration: Created /etc/modprobe.d/speaker.conf and tested adding options snd_soc_sof_8336 quirk=0x01 , followed by a full reboot.
Infinix Linux Audio Fix Script: Cloned and ran the community infinix-XL422-linux-audio-fix patch script (which applies HDA pin overrides and an ALSA volume sync service) and rebooted, though it appears geared toward the XL422/HDA architecture rather than the ES8336 SOF codec.
Distro & Firmware Checks: Confirmed sof-firmware is present; also noticed similar behavior on other Linux distributions (Ubuntu/Fedora) while audio works completely fine on Windows 10.
Has anyone successfully configured the snd_soc_sof_8336 driver or found the working quirk value / UCM2 profile for the Infinix INBook X1 Slim (ES8336) on Zorin OS? Any guidance on kernel parameters or dmesg logs I should share would be greatly appreciated!
Hm..beside what you have already tried, I only found reports that it could work with kernel 5.15. You could try it with Zorin 17 and install kernel 5.15 there, but that's much effort just for a test.
Stop the test with Ctrl+C. If it reports an error, include the exact message. If it runs without an error but the speakers stay silent, that points more toward codec routing, speaker amplifier, or board-specific configuration than a missing ALSA playback device.
One important correction before changing anything: don’t add another quirk value until modinfo -p confirms that quirk is a supported parameter and shows how it is used. If it is supported, use the actual module name, snd_soc_sof_es8336, and change only one value at a time.
