No boot device found error after a fresh clean install
Hello guys. I need help. I'm a new user of zorin os and i wanted to install it on my old hp elitebook 8460p witch is not uefi capable. So i created the live cd of the os using rufus for non uefi sytems. Now i can boot normally on the usb drive but once the install process is done, when i try to reboot on internal drive it shows the "no bootable drive found" error. I tried to set the bios but i don't understand what i have done wrong. Any help or advices would be really great. Thanks in advance
PS: there is nothing else on the internal ssd drive of the laptop
If you have a legacy BIOS, you should make sure that Rufus is formatted in MBR (partition scheme) for BIOS (target system) when you create it.
Also switch off secure boot and fast boot in the BIOS.
After installation, ubuntu (as Zorin is called) should be set to the first position in the boot sequence in the BIOS.
Hi and welcome. Windows systems usually have hard drive settings in BIOS set to RAID, this should be changed to AHCI.
Are you installing Zorin instead of Windows or alongside Windows (or another OS)?
Is this a Dual-Boot System or Zorin-only? Did You take a Look in the BIOS Boot Order? If not, take a Look at this and if You see an ''ubuntu'' entry set it to Position 1.
