I clicked "software", searched for "Claude", selected "Claude Desktop" installed it.
Now how do I open it? There's no shortcut anywhere and I don't know where stuff gets installed.
I expected there to be a shorcut added to the start menu.
Forpli
2
Do you have installed the snap package?
Maybe it is defective, many problems posted here:
Is it shown as installed? You could search for the .desktop file.
You could open the Program ''Main Menu'' and check there the Categories if the is an entry for it and if it is marked as active.
I did look there, it's not there. That would be the place to manually add it correct?
If I knew were it was installed. I spend most of my time on windows.
How is it with @Forpli's Question here:
Is Claube installed as Snap? You can check that when You look in Gnome Software or type in Terminal snap list and check if it is in the List.
