im using zorin os lite at first try using safe graphic it works.
second try using normal boot (not safe graphic) and after few seconds terminal then flash my monitor and no display just like no compatible resolution (input signal out of range).
after that i install zorin os then after i thought display would be normal but just like second try using normal boot (input signal out of range) how do i fix it?
Can you give us the specification of your machine? Notebook/Desktop and Graphics card and RAM? Boot with live media, open a terminal (Ctrl+ Alt+ T) and enter:
sudo lshw -C video
and post back the results.
specs
intel core 2 duo e7500
Nvidia geforce 610
ram 3gb
this is from sudo lshw -c video
*-display UNCLAIMED
product: GF119 [GeForce GT 610]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f2000000-f2ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:2000(size=128) memory:c0000-dffff
You can try adding the nomodeset grub parameter:
There may be times that a user must add a specialized grub parameter in order to overcome an issue.
The purpose of this guide is not to provide parameters, as that would be a case by case basis. It is to provide a guide on how to add one.
To add a parameter, in a terminal (TTY, Recovery Prompt or Terminal Emulator) run:
sudo nano /etc/default/grub
Arrow key down to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" and place your parameter within the quotation tags. For example if you are adding th…
I see you have a 610. I can't speak for Lite but I could not use Zorin Core with a 720, minimum requirement was a 730. I upgraded to a GT1030.
Might need the nvidia-352 driver:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-352
sudo reboot
But, I can't say whether that will solve the issues; might not like the older drivers.. But that card was pulling up 352 through Nvidia.
Would try the nomodeset Grub option first though.
Just covering bases: Do you get anything popping up in Additional Drivers through Software Updater settings?
system
Closed
February 26, 2024, 9:42pm
7
