No sound after update
its a utility to show what you have it isnt installed for some reason
will help determin if you have pulse or pipewire
shows I have pipewire
when i run the pactl info command that is
if the pipewire isnt there then its pulse
I tried installing pactl and then tested pactl info. The output is:
Anslutningsfel: Anslutning nekades
(Connection error: Connection denied)
sudo apt install pulseaudio-utils
you mean this?
I tried disabling Fast Boot, but it didn't help. Secure Boot is grayed out.
Yes, I did that and after the install I tried pactl info
ok have you tryed switching to X11 to see if this presists?
to do that log out then click area where you would type in password ....look to lower right for a gear then hit zorin desktop on xorg then log in
Yes, I tried that but it didn't help. Still no audio units.
I also tried plugging in my husband's USB headset, but it didn't work either.
sudo apt install --reinstall -y pipewire pipewire-pulse wireplumber
let try a reinstall
then after it installs(I hope) enter these lines 1 at a time
systemctl --user daemon-reload
systemctl --user restart pipewire wireplumber pipewire-pulse
then will try these 2 line each by itself
wpctl status
speaker-test -t sine -f 1000 -l 1
that last one you should hear a tone just close the terminal to stop it
Yes!!! Wonderful!
This did it.
Thank you so much for your support!
I was totally lost without you.
<3
Np glad it worked...IF i helped enough give a solution so others know this is solved... :innocent:
Absolutely! Do I do anything more than mark the post with the green check?
you did good its shows the box next to your post with a checkmark in it....and thanks.... :innocent:
Should be Pipwire.
