Hi, I accepted the latest updates for my system and afterwards it can't detect any sound units (Don't know if it's the proper word, I use it in swedish) - no output and no input. I have both a headset with microphone and a speaker, both connected with 3.5 mm line in to my stationary computer. Everything worked fine before the update.
Any suggestions?
You could try with going back to an older Kernel. to do that, choose on the GRUB Menu on Startup ''Advanced Options'' and there the older Kernel. Should be -38.
Another Thing to try could be to switch from Wayland to Xorg. To do that, go to the Login Screen. Click there on Your Profile so that the Password Field appears. When it is appeared, You should see in the bottom right Corner a Gear Icon. Click on it and choose ''Zorin Desktop on Xorg' and then log in and check if the Sound works again.
Also: Are Secure Boot and Fast Boot in BIOS disabled?
Bummer. We have to wait until a Zorin user can tell us, which audio server it uses. IF we can get that restarted then you can access alsamixer to check the settings of the audio. Also it could be that the audio server is down is the cause of missing audio.
