No sound from Bluetooth connected headphones
Hi, and welcome cosplay. Can you give us a bit more information? Is the Bluetooth built into the Notebook you are using?
Can you follow this guide to provide some information?
So installing bluez might be a good place to start if not present. Open a terminal (Ctrl+ Alt+ T) and enter:
sudo apt-get update && sudo apt-get dist-upgrade
then:
sudo apt install bluez
Restart your machine and then see if anything has changed by going to Settings from the Menu and select Bluetooth:
Bluetooth works again, thanks
