Hello,
I am having Dell Inspiron 3542 Laptop. The hardware configuration is as under:
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
Subsystem: Dell Haswell-ULT DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities:
Kernel driver in use: hsw_uncore
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
Subsystem: Dell Haswell-ULT Integrated Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 46
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: i915
Kernel modules: i915
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
Subsystem: Dell Haswell-ULT HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 54
Memory at f7a04000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
Subsystem: Dell 8 Series HECI
Flags: bus master, fast devsel, latency 0, IRQ 53
Memory at f7a0d000 (64-bit, non-prefetchable) [size=32]
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
Subsystem: Dell 8 Series HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 55
Memory at f7a00000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 40
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Capabilities:
Kernel driver in use: pcieport
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: f7900000-f79fffff
Capabilities:
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f7800000-f78fffff
Prefetchable memory behind bridge: 00000000f2100000-00000000f21fffff
Capabilities:
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f6000000-f70fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
Capabilities:
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04) (prog-if 20 [EHCI])
Subsystem: Dell 8 Series USB EHCI
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7a0b000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci-pci
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
Subsystem: Dell 8 Series LPC Controller
Capabilities:
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Subsystem: Dell 8 Series SATA Controller 1 [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 44
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f7a0a000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
Subsystem: Dell 8 Series SMBus Controller
Flags: medium devsel, IRQ 3
Memory at f7a09000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel modules: i2c_i801
06:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Subsystem: Dell QCA9565 / AR9565 Wireless Network Adapter
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at f7900000 (64-bit, non-prefetchable) [size=512K]
Expansion ROM at f7980000 [disabled] [size=64K]
Capabilities:
Kernel driver in use: ath9k
Kernel modules: ath9k
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
Subsystem: Dell RTL810xE PCI Express Fast Ethernet controller
Flags: bus master, fast devsel, latency 0, IRQ 19
I/O ports at e000 [size=256]
Memory at f7800000 (64-bit, non-prefetchable) [size=4K]
Memory at f2100000 (64-bit, prefetchable) [size=16K]
Capabilities:
Kernel driver in use: r8169
Kernel modules: r8169
08:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
Subsystem: Dell GM108M [GeForce 840M]
Flags: bus master, fast devsel, latency 0, IRQ 56
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at d000 [size=128]
[virtual] Expansion ROM at f7000000 [disabled] [size=512K]
Capabilities:
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Last night, I installed Zorin OS 15.3. Everything is running smooth except for the sound. When I test speakers in sound settings, sound if coming from the left channel but not from the right channel. However, this is not happening in Windows 10.
I researched on the internet to find any clues, but to no avail. I even tried searching for the Dell sound drivers, but there aren't any.
Furthermore, I just can't figure out what could be wrong. Any help will be highly appreciated.
Thanks in advance
