No sound in MacBook Pro 2017
Does this support page give helpful info?
I did not think of this way to identify it!
Indeed there is no need for working OS this way.
MacBook Pro 2017
Very helpful. Thank you.
I am afraid that making the audio working on your system is not very easy :frowning:
One easy work around is using external an USB sound card - small one is very small and inexpensive (2 - 6 Euro). It is about the size of a bulky USB memory. High end desktop version would be more than 100 Euro which is of cource too big to carry around with laptop.
Great thing about Linux as well as macOS is that there is no need for installing driver for those external sound cards. Much easy to install compared with Windows.
[edit]
I change the title and category of this thread to attract more help from other forum members.
My other proposal regarding this sound issue is that you keep your macOS and install Zorin (or any other Linux OS) as a virtual machine. Virtual machines create a virtual hardware for the guest OS overcoming hardware incompatibility issues. Even you have completely uninstalled macOS, it should be easy to restore OS on the genuine Apple hardware.
Thanks for the help!
I found a solution to this problem.
1)You need to install git sudo apt install git
2) Install other packages (some of these may already be on your install): apt install wget make gcc linux-headers-generic
3) Clone the driver code: git clone https://github.com/davidjo/snd_hda_macbookpro.git
4)cd snd_hda_macbookpro/
5)sudo ./install.cirrus.driver.sh
But at this stage i encountered error abou linux kernev version 6.17.0 So i tried to install this with the command but in doesnt work. SO i download manually this package and install it and after that repeat command above. After i rebooted mac and sound start working. Ling to download kernel http://archive.ubuntu.com/ubuntu/pool/main/l/linux/linux-source-6.17.0_6.17.0-14.14_all.deb
