No wifi adapter found on z18
Before installing when I tried from thumbdrive, wifi was working. But after installing it didnt work.
Installed on Acer Aspire 14
Secure bootloader disabled.
Tried all the followings. Still no wifi. Please help.
$ sudo apt update
All packages are up to date.
$ sudo apt upgrade
Reading package lists... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo lshw -C network
*-network UNCLAIMED
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 10
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: iomemory:300-2ff memory:3013318000-301331bfff
*-network
physical id: 15
bus info: usb@4:1
logical name: enx00051b68141f
serial: 00:05:1b:68:14:1f
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=cdc_ncm driverversion=6.17.0-14-generic firmware=CDC NCM (NO ZLP) ip=192.168.12.50 link=yes multicast=yes port=twisted pair speed=1Gbit/s
$ rfkill list
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
$ nmcli radio wifi on
Did You checked the ''Additional Drivers'' Tab if there is a Driver offered? Does Your system run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
When it runs in Wayland, I would suggest to try it with switching to X11/Xorg. to do that, go to the Login Screen. Click there on Your Profile so that the Password Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on the and choose the Option ''Zorin Desktop on Xorg''.
Thank for the response. I moved onto Fedora. I will give your suggestion about xorg a try another time. Oh I did check under Additional Drivers. Nothing was recommended there.
